Hi everyone! I'm fresh from ROScon and am trying to impiment hector_quadrotor on 12.04 with fuerte. I am running into a problem with the first demo. What I've done:
1.I took down every part of the stack to make sure that I didn't miss anything.
svn co http://tu-darmstadt-ros-pkg.googlecode.com/svn/trunk
2.I then attempted to build the stack
parcon@PC-MBA:~/ros_workspace/trunk$ rosmake hector_quadrotor
[ rosmake ] rosmake starting...
[ rosmake ] Packages requested are: ['hector_quadrotor']
[ rosmake ] Logging to directory /home/parcon/.ros/rosmake/rosmake_output-20120523-155917
[ rosmake ] Expanded args ['hector_quadrotor'] to:
['hector_quadrotor_gazebo', 'hector_quadrotor_teleop', 'hector_quadrotor_gazebo_plugins', 'hector_quadrotor_demo', 'hector_quadrotor_urdf']
[rosmake-0] Starting >>> roslang [ make ]
[rosmake-1] Starting >>> common_rosdeps [ make ]
[rosmake-2] Starting >>> std_msgs [ make ]
[rosmake-1] Finished <<< common_rosdeps ROS_NOBUILD in package common_rosdeps
[rosmake-1] Starting >>> ogre [ make ]
[rosmake-3] Starting >>> geometry_msgs [ make ]
[rosmake-0] Finished <<< roslang ROS_NOBUILD in package roslang
No Makefile in package roslang
[rosmake-0] Starting >>> roscpp [ make ]
[rosmake-2] Finished <<< std_msgs ROS_NOBUILD in package std_msgs
No Makefile in package std_msgs
[rosmake-2] Starting >>> roslib [ make ]
[rosmake-3] Finished <<< geometry_msgs ROS_NOBUILD in package geometry_msgs
No Makefile in package geometry_msgs
[rosmake-1] Finished <<< ogre ROS_NOBUILD in package ogre
[rosmake-3] Starting >>> sensor_msgs [ make ]
[rosmake-2] Finished <<< roslib ROS_NOBUILD in package roslib[ sensor_msgs: 0.0 sec ] [ bullet... [ 4 Active 5/67 Complete ]
No Makefile in package roslib
[rosmake-1] Starting >>> bullet [ make ]
[rosmake-2] Starting >>> colladadom [ make ]
[rosmake-0] Finished <<< roscpp ROS_NOBUILD in package roscpp
No Makefile in package roscpp
[rosmake-0] Starting >>> urdf_interface [ make ]
[rosmake-1] Finished <<< bullet ROS_NOBUILD in package bullet
[rosmake-1] Starting >>> std_srvs [ make ]
[rosmake-3] Finished <<< sensor_msgs ROS_NOBUILD in package sensor_msgs
No Makefile in package sensor_msgs
[rosmake-2] Finished <<< colladadom ROS_NOBUILD in package colladadom
[rosmake-2] Starting >>> rosconsole [ make ]
[rosmake-3] Starting >>> gazebo_msgs [ make ]
[rosmake-0] Finished <<< urdf_interface ROS_NOBUILD in package urdf_interface
[rosmake-0] Starting >>> urdf_parser [ make ]
[rosmake-1] Finished <<< std_srvs ROS_NOBUILD in package std_srvs
No Makefile in package std_srvs
[rosmake-1] Starting >>> collada_parser [ make ]
[rosmake-3] Finished <<< gazebo_msgs ROS_NOBUILD in package gazebo_msgs
[rosmake-2] Finished <<< rosconsole ROS_NOBUILD in package rosconsole
No Makefile in package rosconsole
[rosmake-2] Starting >>> angles [ make ]
[rosmake-3] Starting >>> rospy [ make ]
[rosmake-0] Finished <<< urdf_parser ROS_NOBUILD in package urdf_parser
[rosmake-1] Finished <<< collada_parser ROS_NOBUILD in package collada_parser
[rosmake-1] Starting >>> rostest [ make ]
[rosmake-2] Finished <<< angles ROS_NOBUILD in package angles
[rosmake-3] Finished <<< rospy ROS_NOBUILD in package rospy
No Makefile in package rospy
[rosmake-0] Starting >>> urdf [ make ]
[rosmake-2] Starting >>> roswtf [ make ]
[rosmake-1] Finished <<< rostest ROS_NOBUILD in package rostest
No Makefile in package rostest
[rosmake-3] Starting >>> message_filters [ make ]
[rosmake-1] Starting >>> rosgraph_msgs [ make ]
[rosmake-3] Finished <<< message_filters ROS_NOBUILD in package message_filters
No Makefile in package message_filters
[rosmake-3] Starting >>> rosservice [ make ]
[rosmake-2] Finished <<< roswtf ROS_NOBUILD in package roswtf
No Makefile in package roswtf
[rosmake-1] Finished <<< rosgraph_msgs ROS_NOBUILD in package rosgraph_msgs
No Makefile in package rosgraph_msgs
[rosmake-2] Starting >>> tf [ make ]
[rosmake-1] Starting >>> rosbuild [ make ]
[rosmake-0] Finished <<< urdf ROS_NOBUILD in package urdf
[rosmake-1] Finished <<< rosbuild ROS_NOBUILD in package rosbuild
No Makefile in package rosbuild
[rosmake-1] Starting >>> protobuf [ make ]
[rosmake-0] Starting >>> nav_msgs [ make ]
[rosmake-3] Finished <<< rosservice ROS_NOBUILD in package rosservice
No Makefile in package rosservice
[rosmake-3] Starting >>> dynamic_reconfigure [ make ]
[rosmake-2] Finished <<< tf ROS_NOBUILD in package tf
[rosmake-0] Finished <<< nav_msgs ROS_NOBUILD in package nav_msgs
No Makefile in package nav_msgs
[rosmake-2] Starting >>> mk [ make ]
[rosmake-3] Finished <<< dynamic_reconfigure ROS_NOBUILD in package dynamic_reconfigure
[rosmake-1] Finished <<< protobuf ROS_NOBUILD in package protobuf
[rosmake-1] Starting >>> pluginlib [ make ]
[rosmake-3] Starting >>> gazebo [ make ]
[rosmake-0] Starting >>> bond [ make ]
[rosmake-2] Finished <<< mk ROS_NOBUILD in package mk
No Makefile in package mk
[rosmake-2] Starting >>> smclib [ make ]
[rosmake-1] Finished <<< pluginlib ROS_NOBUILD in package pluginlib
[rosmake-1] Starting >>> diagnostic_msgs [ make ]
[rosmake-0] Finished <<< bond ROS_NOBUILD in package bond
[rosmake-0] Starting >>> rosbag [ make ]
[rosmake-1] Finished <<< diagnostic_msgs ROS_NOBUILD in package diagnostic_msgs
No Makefile in package diagnostic_msgs
[rosmake-1] Starting >>> diagnostic_updater [ make ]
[rosmake-2] Finished <<< smclib ROS_NOBUILD in package smclib
[rosmake-2] Starting >>> bondcpp [ make ]
[rosmake-1] Finished <<< diagnostic_updater ROS_NOBUILD in package diagnostic_updater
[rosmake-0] Finished <<< rosbag ROS_NOBUILD in package rosbag
No Makefile in package rosbag
[rosmake-0] Starting >>> pcl [ make ]
[rosmake-1] Starting >>> self_test [ make ]
[rosmake-2] Finished <<< bondcpp ROS_NOBUILD in package bondcpp
[rosmake-2] Starting >>> nodelet [ make ]
[rosmake-0] Finished <<< pcl ROS_NOBUILD in package pcl
No Makefile in package pcl
[rosmake-1] Finished <<< self_test ROS_NOBUILD in package self_test
[rosmake-0] Starting >>> image_transport [ make ]
[rosmake-1] Starting >>> driver_base [ make ]
[rosmake-2] Finished <<< nodelet ROS_NOBUILD in package nodelet
[rosmake-2] Starting >>> nodelet_topic_tools [ make ]
[rosmake-1] Finished <<< driver_base ROS_NOBUILD in package driver_base
[rosmake-0] Finished <<< image_transport ROS_NOBUILD in package image_transport
[rosmake-1] Starting >>> hector_sensors_description [ make ]
[rosmake-0] Starting >>> odometry_to_tf [ make ]
[rosmake-2] Finished <<< nodelet_topic_tools ROS_NOBUILD in package nodelet_topic_tools
[rosmake-2] Starting >>> pcl_ros [ make ]
[rosmake-2] Finished <<< pcl_ros ROS_NOBUILD in package pcl_ros
[rosmake-2] Starting >>> visualization_msgs [ make ]
[rosmake-2] Finished <<< visualization_msgs ROS_NOBUILD in package visualization_msgs
No Makefile in package visualization_msgs
[rosmake-2] Starting >>> laser_geometry [ make ]
[rosmake-2] Finished <<< laser_geometry ROS_NOBUILD in package laser_geometry
[rosmake-2] Starting >>> orocos_kdl [ make ]
[rosmake-2] Finished <<< orocos_kdl ROS_NOBUILD in package orocos_kdl
[rosmake-2] Starting >>> python_orocos_kdl [ make ]
[rosmake-2] Finished <<< python_orocos_kdl ROS_NOBUILD in package python_orocos_kdl
[rosmake-2] Starting >>> kdl [ make ]
[rosmake-2] Finished <<< kdl ROS_NOBUILD in package kdl
No Makefile in package kdl
[rosmake-2] Starting >>> tf_conversions [ make ]
[rosmake-2] Finished <<< tf_conversions ROS_NOBUILD in package tf_conversions
[rosmake-2] Starting >>> hector_mapping [ make ]
[rosmake-3] Finished <<< gazebo ROS_NOBUILD in package gazebo
[rosmake-3] Starting >>> hector_gazebo_plugins [ make ]
[ rosmake ] All 21 lines
mkdir -p bin
cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=`rospack find rosbuild`/rostoolchain.cmake ..
[rosbuild] Building package hector_mapping
Failed to invoke /opt/ros/fuerte/bin/rospack deps-manifests hector_mapping
[rospack] Error: package/stack hector_mapping depends on non-existent package eigen
CMake Error at /opt/ros/fuerte/share/ros/core/rosbuild/public.cmake:129 (message):
Failed to invoke rospack to get compile flags for package 'hector_mapping'.
Look above for errors from rospack itself. Aborting. Please fix the
broken dependency!
/opt/ros/fuerte/share/ros/core/rosbuild/public.cmake:203 (rosbuild_invoke_rospack)
CMakeLists.txt:14 (rosbuild_init)
[ rosmake ] Output from build of package hector_mapping written to:
[ rosmake ] /home/parcon/.ros/rosmake/rosmake_output-20120523-155917/hector_mapping/build_output.log
[rosmake-2] Finished <<< hector_mapping [FAIL] [ 0.21 seconds ]
[ rosmake ] Halting due to failure in package hector_mapping.
[ rosmake ] Waiting for other threads to complete.
[rosmake-1] Finished <<< hector_sensors_description [PASS] [ 0.54 seconds ]
[ rosmake ] Last 40 linesometry_to_tf: 1.1 sec ] [ hector_gazebo_plugins: 0.9 sec ] [ 2 Active 52/67 Complete ]
-- Build files have been written to: /home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/build
cd build && make -l4
make[1]: Entering directory `/home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/build'
make[2]: Entering directory `/home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/build'
make[3]: Entering directory `/home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/build'
make[3]: Leaving directory `/home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/build'
[ 0%] Built target rosbuild_premsgsrvgen
[ 10%] Built target ROSBUILD_gensrv_cpp
[ 20%] Built target ROSBUILD_gensrv_lisp
[ 40%] Built target ROSBUILD_gensrv_py
[ 40%] Built target rospack_gensrv
[ 40%] Built target rospack_genmsg_libexe
[ 40%] Built target rosbuild_precompile
[ 50%] Building CXX object CMakeFiles/diffdrive_plugin_6w.dir/src/diffdrive_plugin_6w.o
In file included from /home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/src/diffdrive_plugin_6w.cpp:36:0:
/home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/include/hector_gazebo_plugins/diffdrive_plugin_6w.h:30:27: fatal error: gazebo/Param.hh: No such file or directory
compilation terminated.
make[3]: *** [CMakeFiles/diffdrive_plugin_6w.dir/src/diffdrive_plugin_6w.o] Error 1
make[2]: *** [CMakeFiles/diffdrive_plugin_6w.dir/all] Error 2
make[2]: Leaving directory `/home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/build'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/parcon/ros_workspace/trunk/hector_gazebo/hector_gazebo_plugins/build'
[ rosmake ] Output from build of package hector_gazebo_plugins written to:
[ rosmake ] /home/parcon/.ros/rosmake/rosmake_output-20120523-155917/hector_gazebo_plugins/build_output.log
[rosmake-3] Finished <<< hector_gazebo_plugins [FAIL] [ 0.94 seconds ]
[ rosmake ] Halting due to failure in package hector_gazebo_plugins.
[ rosmake ] Last 40 linesometry_to_tf: 2.2 sec ] [ 1 Active 52/67 Complete ]
-- Configuring done
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
-- Build files have been written to: /home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/build
make[1]: Entering directory `/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/build'
make[2]: Entering directory `/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/build'
make[3]: Entering directory `/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/build'
make[3]: Leaving directory `/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/build'
[ 0%] Built target rospack_genmsg_libexe
[ 0%] Built target rosbuild_precompile
[100%] Building CXX object CMakeFiles/odometry_to_tf.dir/src/odom_to_tf.o
/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/src/odom_to_tf.cpp: In function ‘void sendTransform(const Pose&, const Header&, std::string)’:
/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/src/odom_to_tf.cpp:36:26: error: no matching function for call to ‘btMatrix3x3::btMatrix3x3(tf::Quaternion&)’
/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/src/odom_to_tf.cpp:36:26: note: candidates are:
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:61:20: note: btMatrix3x3::btMatrix3x3(const btMatrix3x3&)
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:61:20: note: no known conversion for argument 1 from ‘tf::Quaternion’ to ‘const btMatrix3x3&’
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:52:2: note: btMatrix3x3::btMatrix3x3(const btScalar&, const btScalar&, const btScalar&, const btScalar&, const btScalar&, const btScalar&, const btScalar&, const btScalar&, const btScalar&)
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:52:2: note: candidate expects 9 arguments, 1 provided
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:43:11: note: btMatrix3x3::btMatrix3x3(const btQuaternion&)
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:43:11: note: no known conversion for argument 1 from ‘tf::Quaternion’ to ‘const btQuaternion&’
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:38:2: note: btMatrix3x3::btMatrix3x3()
/opt/ros/fuerte/stacks/bullet/include/LinearMath/btMatrix3x3.h:38:2: note: candidate expects 0 arguments, 1 provided
make[3]: *** [CMakeFiles/odometry_to_tf.dir/src/odom_to_tf.o] Error 1
make[2]: *** [CMakeFiles/odometry_to_tf.dir/all] Error 2
make[2]: Leaving directory `/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/build'
make[1]: Leaving directory `/home/parcon/ros_workspace/trunk/hector_localization/odometry_to_tf/build'
[ rosmake ] Output from build of package odometry_to_tf written to:
[ rosmake ] /home/parcon/.ros/rosmake/rosmake_output-20120523-155917/odometry_to_tf/build_output.log
[rosmake-0] Finished <<< odometry_to_tf [FAIL] [ 2.26 seconds ]
[ rosmake ] Halting due to failure in package odometry_to_tf.
[ rosmake ] Results:
[ rosmake ] Built 55 packages with 3 failures.
[ rosmake ] Summary output to directory
I believe my problems with running the demo (where gazebo crashes)
roslaunch hector_quadrotor_demo outdoor_flight_gazebo.launch
are a result of these rosmake errors. Anyone have any advice?
Thanks! Parker
Originally posted by 0pc0 on ROS Answers with karma: 78 on 2012-05-23
