In ROS fuerte, using stageros with willow-erratic.world file, everything works good and the stage simulation pops up. However, on clicking on View -> Save screenshots exits the simulation and gives the following error,
err: Unable to open stage-000000.png (/tmp/buildd/ros-fuerte-stage-1.6.6/debian/ros-fuerte-stage/opt/ros/fuerte/stacks/stage/build/stage/libstage/canvas.cc Screenshot)
Segmentation fault
Any solutions ?
Originally posted by Arkapravo on ROS Answers with karma: 1108 on 2012-05-13
Comment by Eric Perko on 2012-05-13:
Can you try compiling stage from source... I'm curious to see if it's just trying to save files to e.g. /opt/ros where it doesn't have permissions to write and then not failing gracefully.
Comment by Arkapravo on 2012-05-13:
@Eric Perko Okay ! things just got worse, I deleted the stage at /opt and tried to build revision 39428 of stage svn - that did not build - number of errors ! Now, I am in a dilemma !
You should have uninstalled simulator-stage, not just deleted it. You could also try reinstalling and then giving yourself permissions (e.g. chmod -R 777 stage_dir), but at this point you may just want to file a ticket for it - no matter the cause, its still a bug if it doesn't work from the .debs
@Eric Perko As silly it may sound, I have never filed a ticked - I am getting these bugs in fuerte (another one at - http://answers.ros.org/question/33044/rosversion-in-fuerte) - but somehow filing a ticket doesn't seem a very easy job to me - tried it once, the log in gave some odd error ....
@Eric Perko One more thing, in fuerte stage is stage NOT simulator_stage ! which is also an alteration from diamondback and electric !
Right, I forgot Stage became a unary stack. You can file a ticket by finding the correct bug tracker (first place to look is the "report bugs" link on the package docs (e.g. http://ros.org/wiki/stage#Report_a_Bug). You may have to create an account if you don't already have one.
For many ROS packages, an account on gforge (https://code.ros.org/gf/) will suffice. Any packages on KForge will require a separate kforge.ros.org account.
@Eric Perko Okay - doing it ! I guess a gforge account will work with stage ?
Yes. Stage package uses the ros-pkg trac, so the code.ros.org account is what you need.
@Eric Perko https://code.ros.org/trac/ros-pkg/ticket/5442
Go ahead and post that ticket link as the answer, so that people that come to this question later can find it (and then accept it once you are able to... after a week or so I think).
Comment by Arkapravo on 2012-05-14:
@Eric Perko A personal opinion, but I have not found Stage 4.1.1 much to my liking. Stage 3.2.2 was much better, faster, reliable ....
Ticket raised, https://code.ros.org/trac/ros-pkg/ticket/5442
Originally posted by Arkapravo with karma: 1108 on 2012-05-13
