I have created a talker in in rosjava and have created a listener in C++ code. When I run the talker and the start the listener I see this on the talker screen...
May 11, 2012 2:53:01 PM org.jboss.netty.channel.DefaultChannelPipeline WARNING: An exception was thrown by a user handler while handling an exception event ([id: 0x4b3ec2dd, /127.0.0.1:40815 :> /127.0.0.1:42634] EXCEPTION: java.lang.IllegalStateException: Unexpected message MD5 fee433c609b213f85c484ba6dc0f8c7c != 74765c06a94b3265f1c21e7d818205cd) org.ros.exception.RosRuntimeException: java.lang.IllegalStateException: Unexpected message MD5 fee433c609b213f85c484ba6dc0f8c7c != 74765c06a94b3265f1c21e7d818205cd at org.ros.internal.transport.ConnectionTrackingHandler.exceptionCaught(ConnectionTrackingHandler.java:73) at org.jboss.netty.channel.Channels.fireExceptionCaught(Channels.java:432) at org.jboss.netty.channel.AbstractChannelSink.exceptionCaught(AbstractChannelSink.java:52) at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:302) at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:317) at org.jboss.netty.handler.codec.frame.FrameDecoder.callDecode(FrameDecoder.java:299) at org.jboss.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:216) at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:274) at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:261) at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:349) at org.jboss.netty.channel.socket.nio.NioWorker.processSelectedKeys(NioWorker.java:280) at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:200) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.IllegalStateException: Unexpected message MD5 fee433c609b213f85c484ba6dc0f8c7c != 74765c06a94b3265f1c21e7d818205cd at com.google.common.base.Preconditions.checkState(Preconditions.java:145) at org.ros.internal.node.topic.DefaultPublisher.finishHandshake(DefaultPublisher.java:179) at org.ros.internal.transport.tcp.TcpServerHandshakeHandler.handleSubscriberHandshake(TcpServerHandshakeHandler.java:99) at org.ros.internal.transport.tcp.TcpServerHandshakeHandler.messageReceived(TcpServerHandshakeHandler.java:69) ... 12 more
I know that the talker and listener are working correctly all in rosjava but when I try to connect it with C++ node I get this error. Roscore is running on localhost:11311. What am I missing here? It also fails when I do a rostopic echo chatter.
Thanks
Originally posted by mikegulf on ROS Answers with karma: 56 on 2012-05-11
Comment by joq on 2012-05-11:
Looks like the message checksums do not match. What message are you trying to send?
Comment by mikegulf on 2012-05-11:
I tried doing custom messages at first but then checked by sending a string and it did the same thing.
The message means that the Rosjava publisher is trying to publish a message to a topic on which the C++ listener already listens, but the publisher's message type doesn't match the subscriber's message type. This can have two reasons:
  1. Publisher and subscriber use different message types (e.g., one uses std_msgs/String and the other std_msgs/Int8).
  2. Both use the same message type, but were built with different versions of it.
To debug (1), you can do the following:
  • start a new roscore (!)
  • start the subscriber
  • do a rosnode info on the subscriber
  • repeat the same for the publisher (after restarting the roscore) and see whether subscription and publication match up
To debug (2), you can
  • make sure that your ROS_PACKAGE_PATH and ROS_ROOT are set up correctly
  • rebuild your message package, if you are using custom messages
  • rebuild your subscriber and your publisher (that way you know that both used the same environment variables when they were build)
I don't have any experience with the newest rosjava build system using gradle, but before the switch to gradle, it usually also helped to do the following, then rebuild the rosjava nodes:
rm -rf ~/.m2/ ~/.ros/rosjava/
(cd $(rosstack find rosjava_core) && hg clean --all)
Originally posted by Martin Günther with karma: 11816 on 2012-05-13
Comment by mikegulf on 2012-05-17:
Thanks for the tips. It turned out I was sending one type of message and wanting to receive a different one. Once I got things aligned and was sending the proper message I was good. I appreciate your help.
Comment by Martin Günther on 2012-05-21:
Glad to help! Please mark the answer as correct (check box to the left).
