when I am trying to launch huskyA200_gazebo map_office.launch.. I am getting the following error. Please help what ia have to chande in this header file /opt/ros/electric/stacks/visualization_common/ogre/build/ogre_src_v1-7-3/OgreMain/include/OgreAxisAlignedBox.h:
roslaunch huskyA200_gazebo map_office.launch ... logging to /home/shakimca/.ros/log/677b8c94-9a60-11e1-b0b1-386077f24ea0/roslaunch-Adept7-8482.log Checking log directory for disk usage. This may take awhile. Press Ctrl-C to interrupt Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://Adept7:55956/
SUMMARY
PARAMETERS
  • /rosversion
  • /rosdistro
NODES / gazebo (gazebo/gazebo)
core service [/rosout] found process[gazebo-1]: started with pid [8500] Gazebo multi-robot simulator, version 0.10.0
Part of the Player/Stage Project [http://playerstage.sourceforge.net]. Copyright (C) 2003 Nate Koenig, Andrew Howard, and contributors. Released under the GNU General Public License.
Param [quickStepPreconIters] is deprecated: [replace quickStepPreconIters with stepPreconIters] Param [quickStep] is deprecated: [replace quickStep with stepType] Param [quickStepIters] is deprecated: [replace quickStepIters with stepIters] Param [quickStepW] is deprecated: [replace quickStepW with stepW] ScopedName[gplane] ScopedName[willow_map] ScopedName[point_white] gazebo: /tmp/buildd/ros-electric-visualization-common-1.6.2**/debian/ros-electric-visualization-common/opt/ros/electric/stacks/visualization_common/ogre/build/ogre_src_v1-7-3/OgreMain/include/OgreAxisAlignedBox.h:252: void Ogre::AxisAlignedBox::setExtents(const Ogre::Vector3&, const Ogre::Vector3&): Assertion `(min.x <= max.x && min.y <= max.y && min.z <= max.z) && "The minimum corner of the box must be less than or equal to maximum corner"' failed.** [gazebo-1] process has died [pid 8500, exit code -6]. log files: /home/shakimca/.ros/log/677b8c94-9a60-11e1-b0b1-386077f24ea0/gazebo-1*.log all processes on machine have died, roslaunch will exit shutting down processing monitor... ... shutting down processing monitor complete done
Originally posted by SHAKIMCA on ROS Answers with karma: 11 on 2012-05-09
Comment by DimitriProsser on 2012-05-10:
What graphics card are you using?
Look at the answer to this question. It might help you solve your issue.
Originally posted by DimitriProsser with karma: 11163 on 2012-05-10
