I'm looking for a wireless camera solution that could feed what it sees into the usb_cam node. I want to experiment with ar_pose however the camera is to be mounted on a quadcopter and obviously running a cam would be disadvantageous. Is there a camera system that would work over short range (5-10 m or so) that would permit this?
Originally posted by mrtc on ROS Answers with karma: 112 on 2012-05-09
Comment by William on 2013-04-05:
@Chad Rockey experimented with a wireless camera at some point.
You can try the Trek AI ball. They are kinda expensive ($80) and run through batteries quickly, so I would power them externally.
http://www.thumbdrive.com/aiball/
There's a ROS MJPEG driver here:
https://github.com/chadrockey/mjpeg_network_camera
Originally posted by Chad Rockey with karma: 4541 on 2013-04-05
