The Arduino is really an AVR Atmega328p. The Arduino is a fine off-the-shelf implementation of this microcontroller, but if you make many of them, you can buy the chip for less than $3 each in bulk, and it requires very little circuitry to run on its own -- a crystal and a couple of capacitors to run at 20 Mhz, or not even that if you can run at the built-in 8 MHz resonant oscillator frequency.
It's fine for generating control signals: Servo PWM, step/direction, control for H-bridges, etc.)
It's also OK for running sensors: Ultrasonic time measurement, IR voltage conversion measurement, on/off contactors, etc -- this includes whatever optical sensor you'd use for "line sensing."
There will be a little code space left over after doing these tasks, so the simple control loop of "is the line to the right, left, or center of me -> do the appropriate turn" can be built into that system. However, as soon as you want to do something bigger, like path planning, environmental awareness, memory, SLAM, etc, you will not be able to fit that into the Arduino.
Thus, the best system for your requirements probably includes tying all the physical hardware to the Arduino, and then talking to the Arduino from the Raspberry Pi. The RPi has a modicum of CPU power (700 MHz ARM) and RAM (256-512 MB RAM) and thus can run higher-level control algorithms like path planning, localization, SLAM, etc.
If you go with a bare AVR controller, there are UART outputs on the Raspberry Pi, but the problem is that the RPi is 3.3V and the Arduino Uno is 5V. Either go with a 3.3V Arduino version, or use a voltage divider to step down 5.0V output from the Arduino to the 3.3V input of the Raspberry Pi. I use a 2.2 kOhm high and 3.3 kOhm low resistor and it works fine. You can feed the 3V output from the Raspberry Pi directly into the RXD of the AVR, because it will treat anything at 1.2V or up as "high."
