Hi, I'm trying to follow this tutorial but when I launch the program I get this warning:
[INFO] [WallTime: 1335361633.048001] Creating ultrasonic with name
  ultrasonic_sensor on PORT_2
[WARN] [WallTime: 1335361633.284565] caught an exception nxt.error.DirProtError
My yaml file has this characteristics:
- type: ultrasonic
  frame_id: r_ultrasonic_link
  port: PORT_2
  spread_angle: 0.2
  min_range: 0.01
  max_range: 2.5
  desired_frequency: 10.0
Supposedly, these lines creates an ultrasonic sensor with a spread angle of 0.2m, a min range of 0.01m, and a max range of 2.5m that is connected to PORT_2.
I only has this problem with the ultrasonic sensor. Touch and color (intensity) sensors work fine. I have the correct firmware (v1.28).
EDIT: I've listed the topics:
$ rostopic list
/intensity_sensor
/joint_command
/joint_state
/joint_states
/rosout
/rosout_agg
/touch_sensor
/ultrasonic_sensor
But when I try to see the topic I get this warning.
$ rostopic echo /ultrasonic_sensor
WARNING: topic [/ul/ultrasonic_sensor] does not appear to be published yet
Thanks in advantage for your help.
Cheers,
Raúl Pérula
Originally posted by raul.perula on ROS Answers with karma: 71 on 2012-04-25
I can't solve the warning, but seems like works.
Originally posted by raul.perula with karma: 71 on 2012-05-21
