I want to make a robot like turtlebot,with kinect and a netbook,turtlebot's netbook has a discrete graphic. I want to do 2d or 3d slam and navigation,then is opencv's image processing,does the netbook need a high performance gpu?Or I just need a good cpu?Atom N570 can be ok?
Thank you.
Originally posted by Starsky Wong on ROS Answers with karma: 13 on 2012-04-25
For visualization, particularly of large point clouds (like are generated by the Kinect), you will need a pretty serious GPU.
Otherwise, you don't need a GPU at all. OpenCV, PCL, etc. are CPU libraries (although both have some experimental GPU features), as are all of the various ROS tools. I don't know enough about Atom CPUs to tell you if that particular one is enough; I can tell you that (save visualization), I've used pretty old netbooks with a lot of success.
Originally posted by Mac with karma: 4119 on 2012-04-25
Comment by Starsky Wong on 2012-04-26:
Thank you!I think I'll do visualization in another PC,but needs data transmission.
Comment by Mac on 2012-04-28:
If you'll be transmitting the point clouds wirelessly, you'll need a pretty serious pipe. PCL has some point-cloud-compression stuff that helps. (Basically, point clouds are lots of data; you have to pay somewhere).
