I'm having problems with the image topics published by Gazebo. A simple check with rviz or image_view yields that somethings wrong with the "encoding" field of the Image message.
I tried to modify this line in the robot urdf I'm using but it turned out after a bit of checking the logs that it does not really do anything with the field no matter if it's set to rgb8 or bgr8.
<xacro:stereo_camera_v0 parent="head_2_link" name="stereo" focal_length="3    57.95" hfov="85" image_format="rgb8" image_width="656" image_height="492" >
Error parsing image format (bgr8), using default Ogre::PF_BYTE_RGB
It is publishing images with encoding field set to sensor_msgs::image_encodings::BGR8 no matter what, while the actual encoding is BGR8.
How can I fix this? I would like to use the same node in Gazebo and on the robot without additional workaround.
Originally posted by Bence Magyar on ROS Answers with karma: 358 on 2012-04-23
The available image_format values for gazebo are R8G8B8, B8G8R8, BAYER_RGGB8, BAYER_BGGR8, BAYER_GBRG8 and BAYER_GRBG8.
Originally posted by hsu with karma: 5780 on 2012-04-25
http://docs.ros.org/jade/api/gazebo_plugins/html/gazebo__ros__camera__utils_8cpp_source.html
there is also "L8" for monochrome images
Originally posted by shaviland3 with karma: 11 on 2016-06-23
