Hello everyone. I was trying to test out the board on my turtlebot (I don't have ROS setup yet but I should have access to my computers soon). I am only using serial commands over realterm. I used a crimping tool, cut out the power-adapter from the Y-splitter and connected the red/brown wires as shown in the manual and plugged them in (as pic1 pic2)
I then set the create to Full mode via realterm but the kinect isn't powered on at all (blinking green light). Can anyone help me power the kinect using just OI (I don't have a laptop to run ROS on atm and I would really like to see if I have any defective hardware.
Thanks, Shriphani P
Originally posted by shriphani on ROS Answers with karma: 1 on 2012-04-21
Comment by lifelonglearner on 2013-07-25:
I am having problem while connecting the kinect power using DB25 connector of Irobot create base. The connector circuit is designed by clearpath robotics to provide 12V DC power to kinect by taking power from pin 10 and 14 of DB25 connector of irobot create base.
The Kinect requires both USB and 12V power to operate.
You should get a multimeter and measure the voltage on the power connector to confirm that it is producing 12V.
Originally posted by ahendrix with karma: 47576 on 2012-04-21
Comment by ahendrix on 2013-07-26:
please ask a new question.
Comment by lifelonglearner on 2013-07-26:
I have asked the question with more detailed information.... need you help. pls visit question here ........
http://answers.ros.org/question/67618/kinect-power-problem-while-connecting-to-the-irobot-create-base/
