Hi, I am trying to implement amcl on rviz using nxt and kinect.
However, it just can't localize itself. I have used rviz 2D pose estimate to select the initial location of the robot as shown below (but no particle cloud is shown after I release my mouse click button -> rviz highlighted the particle cloud in yellow)
image description http://i1214.photobucket.com/albums/cc484/torresho/April2012/amcl_2D_pose_estimate_not_working-1.png
The navigation stack is working perfectly, it can plan the required navigation path and move to the desired destination, as shown in the pictures below:
image description http://i1214.photobucket.com/albums/cc484/torresho/April2012/navigationpath.png
image description http://i1214.photobucket.com/albums/cc484/torresho/April2012/navigationtodestination.png
The rxgraph is shown below (amcl did received all the 4 needed subscribed topics which are /scan, /tf, /map and /initialpose reference) :
image description http://i1214.photobucket.com/albums/cc484/torresho/April2012/amcl_rxgraph_map_topic_connected_but_cannot_localize.png
Clearer Image for rxgraph
The tf_frames is shown below (I can't detect any error with the tf_frames as well ,hmm...):
image description http://i1214.photobucket.com/albums/cc484/torresho/April2012/tfview_framesResult.png
The yaml files:
costmap_common_params.yaml:
obstacle_range: 2.5
raytrace_range: 3.0
footprint: [[0.305, 0.278], [0.04, 0.193], [-0.04, 0.193], [-0.282, 0.178], [-0.282, -0.178], [-0.04, -0.193], [0.04, -0.193], [0.305, -0.278]]
inflation_radius: 0.55
observation_sources: laser_scan_sensor
laser_scan_sensor: {sensor_frame: openni_depth_frame, data_type: LaserScan, topic: scan, marking: false, clearing: true}
global_costmap_params.yaml:
  global_costmap:
  global_frame: /map
  robot_base_frame: base_footprint
  update_frequency: 5.0
  static_map: true
local_costmap_params.yaml:
  local_costmap:
  global_frame: odom_combined
  publish_frequency: 2.0
  static_map: false
  rolling_window: true
  width: 6.0
  height: 6.0
  resolution: 0.05
base_local_planner_params.yaml:
TrajectoryPlannerROS:
  max_vel_x: 0.45
  min_vel_x: 0.1
  max_rotational_vel: 1.0
  min_in_place_rotational_vel: 0.4
  acc_lim_th: 3.2
  acc_lim_x: 2.5
  acc_lim_y: 2.5
  holonomic_robot: False
The launch files:
amcl_diff_with_map_hwk.launch:
<launch>
<node pkg="amcl" type="amcl" name="amcl" output="screen">
  <param name="use_map_topic " value="true"/>
  <!-- Publish scans from best pose at a max of 10 Hz -->
  <param name="odom_model_type" value="diff"/>
  <param name="odom_alpha5" value="0.1"/>
  <param name="transform_tolerance" value="0.2" />
  <param name="gui_publish_rate" value="10.0"/>
  <param name="laser_max_beams" value="30"/>
  <param name="min_particles" value="500"/>
  <param name="max_particles" value="5000"/>
  <param name="kld_err" value="0.05"/>
  <param name="kld_z" value="0.99"/>
  <param name="odom_alpha1" value="0.2"/>
  <param name="odom_alpha2" value="0.2"/>
  <!-- translation std dev, m -->
  <param name="odom_alpha3" value="0.8"/>
  <param name="odom_alpha4" value="0.2"/>
  <param name="laser_z_hit" value="0.5"/>
  <param name="laser_z_short" value="0.05"/>
  <param name="laser_z_max" value="0.05"/>
  <param name="laser_z_rand" value="0.5"/>
  <param name="laser_sigma_hit" value="0.2"/>
  <param name="laser_lambda_short" value="0.1"/>
  <param name="laser_model_type" value="likelihood_field"/>
  <!-- <param name="laser_model_type" value="beam"/> -->
  <param name="laser_likelihood_max_dist" value="2.0"/>
  <param name="update_min_d" value="0.2"/>
  <param name="update_min_a" value="0.5"/>
  <param name="odom_frame_id" value="odom"/>
  <param name="resample_interval" value="1"/>
  <param name="transform_tolerance" value="0.1"/>
  <param name="recovery_alpha_slow" value="0.0"/>
  <param name="recovery_alpha_fast" value="0.0"/>
</node>
</launch>
move_base.launch:
<launch>
  <master auto="start"/>
  <!-- Run the map server -->
  <node name="map_server" pkg="map_server" type="map_server" args="$(find not_good)/Maps/map.pgm 0.05"/>
  <!-- tf /map to /odom_combined -->
  <node pkg="tf" type="static_transform_publisher" name="map_to_odom_combined" args="100 100 0 0 0 0 /map /odom_combined 100"/>
  <!--- Run AMCL -->
  <include file="$(find not_good)/amcl_diff_with_map_hwk.launch" />
  <node pkg="move_base" type="move_base" respawn="false" name="move_base" output="screen">
  <rosparam file="$(find not_good)/costmap_common_params.yaml" command="load" ns="global_costmap" />
  <rosparam file="$(find not_good)/costmap_common_params.yaml" command="load" ns="local_costmap" />
  <rosparam file="$(find not_good)/local_costmap_params.yaml" command="load" />
  <rosparam file="$(find not_good)/global_costmap_params.yaml" command="load" />
  <rosparam file="$(find not_good)/base_local_planner_params.yaml" command="load" />
</node>
</launch>
***Question :Why AMCL is still not working at all? Hmm...
Originally posted by Torres on ROS Answers with karma: 112 on 2012-04-19
If your odometry frame is odom_combined, you should change the odom_frame_id AMCL parameter to odom_combined. I see you have it set to odom.
Originally posted by Eric Perko with karma: 8406 on 2012-04-19
Post score: 4
Comment by Torres on 2012-04-23:
Thanks Eric Perko. =)
Comment by Torres on 2012-05-04:
Thanks Eric Perko =) Could you please have a look at this post as well thanks http://answers.ros.org/question/33319/rosrun-vs-roslaunch
Take a look at this
AMCL provides the transform from /map to /odom_combined so you do not need the static_transform_publisher node running
Originally posted by weiin with karma: 2268 on 2012-04-19
