Hi,
I've been trying to get the camera parameters for my webcam. I'm using the uvc_cam package with camera_calibration package. The commands I use to start are as follows:
roscore
rosrun uvc_camera camera_node
rosrun camera_calibration camacalibrator.py --size 10x7 --square 0.022 image:/usb_cam/image_raw camera:=/ Waiting for service //set_camera_info ... OK`
At this point, nothing happens. Does anyone have a rough idea what is going wrong?
Thanks in advance
Originally posted by derekjchow on ROS Answers with karma: 341 on 2012-04-16
Hi,
There is two things you should try :
First : I see that you type image:/usb_cam but It should be for remapping image:=/usb_cam with the "=" !
Then I did not see what you have set for your camera since it seems that you have paste the answer of you terminal right after you camera:=/ command
So to complete your command line do a rostopic list as follow
vvittori@delos:~/ros_workspace/stereo_robust_matching$ rostopic list
/camera/camera_info
/camera/image_raw
/camera/image_raw/compressed
/camera/image_raw/compressed/parameter_descriptions
/camera/image_raw/compressed/parameter_updates
/camera/image_raw/theora
/camera/image_raw/theora/parameter_descriptions
/camera/image_raw/theora/parameter_updates
/cameraUEYE_node/parameter_descriptions
/cameraUEYE_node/parameter_updates
/rosout
/rosout_agg
and then set the command line as follow (in my exemple /camera/image_raw is my image and /camera is my camera name )
rosrun camera_calibration cameracalibrator.py --size 8x6 --square 0.108 image:=/camera/image_raw camera:=/camera
So for you it should be I gess
rosrun camera_calibration cameracalibrator.py --size 10x7 --square 0.022  image:=/usb_cam/image_raw camera:=/usb_cam
Regards
V.v
Originally posted by Vincent_V with karma: 91 on 2012-04-16
I am having the same problem, although mine is when I try to calibrate 2 PGR Chameleon cameras. I am sure I am remapping correctly, as when I open the rxgraph it shows proper connections. However, the GUI just wont pop up. Following is the code that I have used for the stereo calibration:
rosrun camera_calibration cameracalibrator.py --size 10x6 --square 0.078 right:=/stereo/right/pgr_camera/image_raw left:=/stereo/left/pgr_camera/image_raw right_camera:=/stereo/right/pgr_camera left_camera:=/stereo/left/pgr_camera
Waiting for service /stereo/left/pgr_camera/set_camera_info ...
OK
Waiting for service /stereo/right/pgr_camera/set_camera_info ...
OK
Next, I tried calibrating a single camera in the mono-mode, and although the GUI pops up, I cannot get the calibration lines displayed on my Checkerboard. This is the command that I have used to run in the mono-mode:
rosrun camera_calibration cameracalibrator.py --size 9x5 --square 0.078 image:=/stereo/left/pgr_camera/image_raw cara:=/stereo/left/pgr_camera
OK
Originally posted by amittal with karma: 11 on 2012-07-27
Comment by amittal on 2012-07-27:
ok the gui has booted up!!! I added the --approximate=0.1 parameter to the rosrun
