Following procedure http://www.ros.org/wiki/electric/Installation/OSX/Homebrew 1.6 rosinstall failed at "rosmake ros ros_comm --rosdep-install":
[ rosmake ] Generating Install Script using rosdep then executing. This may take a minute, you will be prompted for permissions. . . Traceback (most recent call last): File "/Users/Ross/ros/ros/tools/rosdep/src/rosdep/installers.py", line 427, in init pop = subprocess.Popen(['port'], stdout=subprocess.PIPE, stderr=subprocess.PIPE)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 672, in init errread, errwrite)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 1202, in _execute_child raise child_exception OSError: [Errno 2] No such file or directory There was an error running macports, make sure it is installed properly.
File "/usr/local/bin/rosinstall", line 5, in pkg_resources.run_script('rosinstall==0.6.13', 'rosinstall')
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources.py", line 489, in run_script self.require(requires)[0].run_script(script_name, ns)
File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/pkg_resources.py", line 1214, in run_script exec script_code in namespace, namespace
File "/Library/Python/2.7/site-packages/rosinstall-0.6.13-py2.7.egg/EGG-INFO/scripts/rosinstall", line 11, in
File "build/bdist.macosx-10.7-intel/egg/rosinstall/rosinstall_cli.py", line 213, in rosinstall_main
File "build/bdist.macosx-10.7-intel/egg/rosinstall/rosinstall_cmd.py", line 88, in cmd_generate_ros_files
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/subprocess.py", line 504, in check_call raise CalledProcessError(retcode, cmd) subprocess.CalledProcessError: Command 'source /Users/Ross/ros/setup.sh && rosmake ros ros_comm --rosdep-install' returned non-zero exit status 255
Kepler-3:~ Ross$
Any assistance is appreciated
Originally posted by RobotRoss on ROS Answers with karma: 141 on 2012-04-16
This looks like it is trying to use macports, Make sure you added:
export ROS_OS_OVERRIDE=osxbrew:lion
To your ~/.bashrc and that you made it take affect by running source ~/.bashrc or by closing and opening the terminal.
The above line is important because it indicates to rosdep that you want to use Homebrew on Lion rather than Macports to resolve your dependencies.
Originally posted by William with karma: 17335 on 2012-04-17
