Hello,
OMPL itself does support the functionality you would like to test (In fact, we are just about to push some changes to the OMPL repository that allow outputting GraphML structures for the trees OMPL planners generate).
However, that functionality is not exposed through the ompl_ros_interface package in ROS Electric. This functionality is implemented for Fuerte, part of the upcoming MoveIt project (not yet released).
So.. the way to do this with ROS Electric will require adding some local hacks on your side:
In the ompl_ros_interface package, the file src/ompl_ros_planning_group.cpp contains the call to the solve() function of an OMPL planner:
bool solved = planner_->solve(request.motion_plan_request.allowed_planning_time.toSec());
This is Line 446 for me.
After that line, you can do something like this:
const ompl::base::PlannerData &pd = planner_->getPlannerData();
planning_models::KinematicState
kstate(*collision_models_interface_->getPlanningSceneState());
for (std::size_t i = 0 ; i < pd.states.size() ; ++i)
omplStateToKinematicStateGroup(pd.states[i], ompl_state_to_kinematic_state_mapping_
kstate->getJointStateGroup(physical_joint_state_group_));
kstate->getJointStateGroup(physical_joint_state_group_)->updateKinematicLinks();
btTransform bt = kstate->getLinkState("some link")->getGlobalLinkTransform();
// do whatever with this; a NodeHandle is available in the class, so this can be published.
The only catch with the above code is that ompl_state_to_kinematic_state_mapping_ is not available in that class, so you have to change the planner class(es), e.g. ompl_ros_joint_planner.cpp, to pass that variable to the planning group.
I'm sorry this is so complicated right now, but for the next version things should be easier.
Originally posted by isucan with karma: 1055 on 2012-04-19
