Hi,
I'm currently setting up an Ubuntu 11.10 with ROS Electric to use rosjava. The build tools are ant 1.8, maven 2.2 and rosws.
Installing rosjava as described link:here unfortunately fails at building the task ':apache_xmlrpc_common:compileJava' with error message:
Building > :apache_xmlrpc_common:compileJava > Resolving dependencies ':apache:apache_xmlrpc_common:compileJava FAILURE: Build failed with an exception.
  • What went wrong: Execution failed for task ':apache_xmlrpc_common:compileJava'.
java.lang.NullPointerException (no error message)
I've got no clue how to fix this; is there anything I missed?
Thanks in advance!
Best regards, Andreas
Originally posted by andreasw on ROS Answers with karma: 61 on 2012-04-14
Post score: 5
If you are using "openjdk-7-jdk" try reverting back to "openjdk-6-jdk". This resolved the issue for me.
Originally posted by bblodget with karma: 73 on 2012-04-16
Comment by 130s on 2013-03-11:
Removing openjdk-7 didn't work for me. Instead @SergioGutierrez's solution worked with this version of rosandroid
Hello again,
Problem solved, it had nothing to do with the build.gradle file, I was using the jre installed from ubuntu software center "OpenJDK Java 7 Runtime", the problem was gone when I installed gradle from apt "sudo apt-get install gradle", wich installs also the necessary java software like javac, after installing I only had to add at the end of the etc/bash.bashrc the JAVA_HOME to "JAVA_HOME=/usr/lib/jvm/default-java", export the variable with "export JAVA_HOME", the PATH to "PATH=$PATH:$JAVA_HOME/bin", export the variable PATH "export PATH", and then all worked nicely.
Best regards.
Originally posted by SergioGutierrez with karma: 86 on 2012-05-08
Post score: 6
