Hi everyone,
I have to control more than one robot at a time. The robots are administered by a central ROS server and can be displayed and controlled using ROS RVIZ at the same time. Every robot runs in a distinct name space such that same topics (like 'move_base/simple_goal') of different robots do not collide.
I was now looking for multiple navigation goal buttons in the tool panel of RVIZ, one for each robot. Currently I have to change the goal topic of the tool each time I intend to give the next robot a moving command. That is not very sophisticated and annoying.
Is there a simple way to have multiple buttons on the toolbar with the same functionality? So far I found nothing that would help.
PS: I am not interested in running ROS cores on each robot and/or opening different instances of RVIZ, just in case someone is about to suggest anything like this ;)
Really appreciate any help and thanks in advance. J.Buesch
Originally posted by JBuesch on ROS Answers with karma: 237 on 2012-04-10
Post score: 6
3 Answers 3
You have to hack rviz source and recompile it. Do as follows:
roscd rviz
cd src/rviz
Edit the file visualization_manager.cpp and go to line 215. You will see there:
createTool< InteractionTool >("Interact", "i" );
createTool< GoalTool >("2D Nav Goal", "g");
Copy the GoalTool line as many times as you need. Syntax:
createTool< TypeOfTheTool >("Label on the button", "shortcut_key");
Save and rosmake rviz. (If you've got precompiled packages remember to delete ROS_NOBUILD before rosmake.)
Now you free to add lines in rviz configuration files .vcg for each tool:
Tool\ Label\ on\ the\ buttonTopic=/robot_n/move_base_simple/goal
Have fun.
Originally posted by Jakub with karma: 1821 on 2012-07-30
Post score: 6
Comment by JBuesch on 2012-08-03:
Would it really be that simple? :) Thanks for the accurate hints!
Comment by Brioche on 2012-10-01:
I was curious: is it possible to add another kind of button or shortcut key? example to stop refreshing the point cloud stream. Something close to RGBDSlam actually, but I want to show also the urdf model of my robot.
Comment by Jakub on 2012-10-01:
For new tools more hacking is required. You have to check out the source code of already existing tools in rviz/src/rviz/tools. All new tools must derive from Tool class (tools.h, tools.cpp). Once done, the above solution would be valid for new tools.
A clean solution would probably be to create an Interactive Marker server that supplies this functionality (e.g. a huge flat box marker that you can click on).
This would also allow you to customize the functionality to your specific application.
Originally posted by dgossow with karma: 1444 on 2012-08-03
Yes, sounds like a reasonable approach.. More generic than hacking the sources.. When I placed the question my environment was not able to use interactive markers, but fortunately that has changed now.
Comment by jayess on 2017-07-26:
I think that this approach is better than the accepted answer as it can be used without hacking.
There's an even simpler way than anyone else has described (except for @joq's answer) that doesn't require any hacking or coding whatsoever. You can add multiple instances of the same tool by using a custom (or modifying the default) .rviz configuration file.
Under the Tools section add:
- Class: rviz/SetGoal
  Topic: /name1/move_base_simple/goal
  Topic: /name2/move_base_simple/goal
where name1 and name2 are the names of your robots.
Post score: 6
