I'm using a for loop to print out values retrieved from a Kinect LaserScan (specifically the "ranges" array). It returns 360 values, each with a number - most of the numbers are 11, but occasionally the numbers from 142-257 (I can't remember the exact range but it's something like that) are different. I believe these are the laser ranges? Am I wrong? Also, what are the numbers measure in? I normally get numbers between 0.5 and 10. If i'm mistaken, could someone explain how to get laser ranges from a kinect laser scan (i'm trying to get the leftmost and rightmost scans)?
Originally posted by AmaneSuzuha on ROS Answers with karma: 1 on 2012-04-07
The sensor_msgs/LaserScan message is documented at http://ros.org/doc/api/sensor_msgs/html/msg/LaserScan.html which is linked from the sensor_msgs wiki page.
Originally posted by tfoote with karma: 58457 on 2012-04-07
