I am trying to install gscam on a Gumstix Overo COM. I have successfully installed the base ROS electric functions such as roscore, rosmake, etc. and I can run roscore. However, rosdep is not able to install yaml-cpp nor tinyxml on the Gumstix's ARM processor. Thus, I tried to install the packages from source:
yaml-cpp : http://code.google.com/p/yaml-cpp/downloads/list
tinyxml : http://code.google.com/p/libtinyxml/
yaml program compiled/installed natively with: cmake, make, sudo make install. Tinyxml I installed by following command: sudo apt-get install libtinyxml-dev
Also I installed necessary dependencies required by gscam:
Image common
svn co https://code.ros.org/svn/ros-pkg/stacks/image_common/tags/electric image_common #common msgs svn co https://code.ros.org/svn/ros-pkg/stacks/common_msgs/tags/electric common_msgs
pluginlib
hg clone https://kforge.ros.org/common/pluginlib -r electric
common rosdeps
hg clone https://kforge.ros.org/common/rosdepcore -r electric
But still problem is still present, I receive following error while trying to compile gscam package:
robot@overo:~/ros_packages/gscam$ rosmake --rosdep-install gscam [ rosmake ] Packages requested are: ['gscam'] [ rosmake ] Logging to directory/home/robot/.ros/rosmake/rosmake_output-20120327-190214 [ rosmake ] Expanded args ['gscam'] to: ['gscam'] [ rosmake ] Generating Install Script using rosdep then executing. This may take a minute, you will be prompted for permissions. . . Failed to find rosdep yaml-cpp for package gscam on OS:ubuntu version:11.04 Failed to find rosdep tinyxml for package gscam on OS:ubuntu version:11.04 WARNING: Rosdeps [u'yaml-cpp', u'tinyxml'] could not be resolved rosdep executing this script: {{{ set -o errexit #No Packages to install }}} [ rosmake ] rosdep successfully installed all system dependencies [ rosmake ] Starting >>> tools/rospack [ rosmake ] Finished >> rosbuild [ make ] [rosmake-0] Finished >> roslang [ make ] [rosmake-0] Finished >> cpp_common [ make ] [rosmake-0] Finished >> roscpp_traits [ make ] [rosmake-0] Finished >> rostime [ make ] [rosmake-0] Finished >> roscpp_serialization [ make ] [rosmake-0] Finished >> roslib [ make ] [rosmake-0] Finished >> xmlrpcpp [ make ] [rosmake-0] Finished >> rosconsole [ make ] [rosmake-0] Finished >> std_msgs [ make ] [rosmake-0] Finished >> rosgraph_msgs [ make ] [rosmake-0] Finished >> roscpp [ make ] [rosmake-0] Finished >> rospy [ make ] [rosmake-0] Finished >> rosclean [ make ] [rosmake-0] Finished >> rosgraph [ make ] [rosmake-0] Finished >> rosparam [ make ] [rosmake-0] Finished >> rosmaster [ make ] [rosmake-0] Finished >> rosout [ make ] [rosmake-0] Finished >> roslaunch [ make ] [rosmake-0] Finished >> rosunit [ make ] [rosmake-0] Finished >> rostest [ make ] [rosmake-0] Finished >> topic_tools [ make ] [rosmake-0] Finished >> rosbag [ make ] [rosmake-0] Finished >> rosbagmigration [ make ] [rosmake-0] Finished >> geometry_msgs [ make ] [rosmake-0] Finished >> sensor_msgs [ make ] [rosmake-0] Finished >> pluginlib [ make ] [rosmake-0] Finished >> message_filters [ make ] [rosmake-0] Finished >> image_transport [ make ] [rosmake-0] Finished >> common_rosdeps [ make ] [rosmake-0] Finished >> camera_calibration_parsers [ make ] [ rosmake ] All 32 linesamera_calibration_parsers: 8.5 sec ] [ 1 Active 31/33 Complete ] {------------------------------------------------------------------------------- mkdir -p bin cd build && cmake -Wdev -DCMAKE_TOOLCHAIN_FILE=`rospack find rosbuild`/rostoolchain.cmake .. [rosbuild] Building package camera_calibration_parsers [rosbuild] Including /home/robot/ros/ros_comm/clients/roslisp/cmake/roslisp.cmake [rosbuild] Including /home/robot/ros/ros_comm/clients/rospy/cmake/rospy.cmake [rosbuild] Including /home/robot/ros/ros_comm/clients/cpp/roscpp/cmake/roscpp.cmake -- Configuring done -- Generating done -- Build files have been written to: /home/robot/ros_packages/image_common/camera_calibration_parsers/build cd build && make -l1 make[1]: Entering directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[2]: Entering directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[3]: Entering directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[3]: Leaving directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' [ 0%] Built target rospack_genmsg_libexe make[3]: Entering directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[3]: Leaving directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' [ 0%] Built target rosbuild_precompile make[3]: Entering directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[3]: Leaving directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[3]: Entering directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' Linking CXX shared library ../lib/libcamera_calibration_parsers.so /usr/bin/ld: /usr/local/lib/libyaml-cpp.a(emitter.cpp.o): relocation R_ARM_THM_MOVW_ABS_NC against `a local symbol' can not be used when making a shared object; recompile with -fPIC /usr/local/lib/libyaml-cpp.a: could not read symbols: Bad value collect2: ld returned 1 exit status make[3]: *** [../lib/libcamera_calibration_parsers.so] Error 1 make[3]: Leaving directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[2]: *** [CMakeFiles/camera_calibration_parsers.dir/all] Error 2 make[2]: Leaving directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/robot/ros_packages/image_common/camera_calibration_parsers/build' -------------------------------------------------------------------------------} [ rosmake ] Output from build of package camera_calibration_parsers written to: [ rosmake ] /home/robot/.ros/rosmake/rosmake_output-20120327-190214/camera_calibration_parsers/build_output.log [rosmake-0] Finished
This question dealt with similar problem but i was unable to solve mine with the help of this previous answer
Originally posted by ajr_ on ROS Answers with karma: 97 on 2012-03-27
Previous error was solved by installing yaml-cpp with following commands...
mkdir build
cd build
cmake -DBUILD_SHARED_LIBS=ON ..
make
sudo make install
Still one error left, which i think is caused by Ubuntu 11.10 and different paths for certain dependencies. I received following error message while trying to rosmake gscam:
[rosmake-0] Starting >>> gscam [ make ]
[ rosmake ] Last 40 linescam: 54.1 sec ]             [ 1 Active 32/33 Complete ]
  -- Configuring done
  -- Generating done
  -- Build files have been written to: /home/robot/ros_packages/gscam/build
  make[1]: Entering directory `/home/robot/ros_packages/gscam/build'
  [rosbuild] Building package gscam
  [rosbuild] Cached build flags older than manifests; calling rospack to get flags
  -- Configuring done
  -- Generating done
  make[2]: Entering directory `/home/robot/ros_packages/gscam/build'
  make[3]: Entering directory `/home/robot/ros_packages/gscam/build'
  make[3]: Leaving directory `/home/robot/ros_packages/gscam/build'
  make[3]: Warning: File `/home/robot/ros/ros_comm/messages/std_msgs/msg_gen/cpp/include/std_msgs/Header.h' has modification time 3.8e+08 s in the future
  [100%] Building CXX object CMakeFiles/gscam.dir/src/gscam.o
  In file included from /usr/include/glib-2.0/glib/galloca.h:34:0,
                   from /usr/include/glib-2.0/glib.h:32,
                   from /usr/include/gstreamer-0.10/gst/gst.h:27,
                   from /home/robot/ros_packages/gscam/src/gscam.cpp:6:
  /usr/include/glib-2.0/glib/gtypes.h:34:24: fatal error: glibconfig.h: No such file or directory
  compilation terminated.
  make[3]: *** [CMakeFiles/gscam.dir/src/gscam.o] Error 1
/glibconfig.h  /usr/include/glib-2.0/glib/Error 2                               e /usr/include/glib-2.0/glib/                  dcp: cannot create regular file `/usr/include/glib-2.0/glib/glibconfig.h': Permission deniedude/glib-2.0/glib/                  lrobot@overo:~/ros_packages/gscam$ man cp                                        c /usr/include/glib-2.0/glib/                  nCP(1)                            User Commands                           CP(1)  i /usr/include/glib-2.0/glib/                  / /usr/include/glib-2.0/glib/---------------------------------------------------}0 /usr/include/glib-2.0/glib/                  .robot@overo:~/ros_packages/gscam
Originally posted by ajr_ with karma: 97 on 2012-04-04
Comment by ajr_ on 2012-04-23:
... this final step was solved by editing CMakelist.txt file inside gscam package. It was necessary to check if output of command pkg-config --cflags glib-2.0 was found on CMakelist.txt file includes. Correct include path was missing so by adding right path to txt file, gscam finally compiled.
Comment by ajr_ on 2012-04-24:
Also some libraries where missing. Running command sudo apt-get install gstreamer0.10-plugins-good helped.
