I started with introduction to working with laserscanner data tutorials:
as it says i executed the following commands in terminal:
roscore in a terminal
then again
$ rosbag play laser.bag[ INFO] [1331111093.757680745]: Opening laser.bag
Waiting 0.2 seconds after advertising topics... done.
Hit space to toggle paused, or 's' to step.
 [RUNNING]  Bag Time: 1275001525.634246   Duration: 41.420635 / 41.431989
Done.
root@arun-Dell-System-Inspiron-N4110:~# rostopic list -v | grep sensor_msgs/LaserScan
root@arun-Dell-System-Inspiron-N4110:~# rosrun rviz rviz
in rviz i could not find the laserscan or /tilt_scan topic. i have inserted the rviz i got after rosrun rviz rviz
can anyone tell me why i'm not able to see the topics list and visualize laserdata in rviz
Originally posted by priya on ROS Answers with karma: 36 on 2012-03-26
If you wait for the rosbag to finish playing and exit it will no longer be published.
I would run rosbag in a separate terminal and pause it while you get rviz setup, or run rostopic list.
Originally posted by tfoote with karma: 58457 on 2012-03-26
