a publisher node in Ubuntu send msg on topic "A",and a subscriber node in windows receive receive msg on topic "A",but it failed,and to put publisher in windows and subscriber in Ubuntu ,it succeeds.Unbuntu runs in a vitual machine, and there is a double red circle around the windows node in rxgraph
Originally posted by bruce1990 on ROS Answers with karma: 1 on 2012-03-02
Sounds like a problem with your network configuration to me. Are you able to ping both systems from each other? Are you running your VM network as a NAT configuration?
If you are able to ping your systems in both directions you should set the ROS_IP variable on both sides to the values you were able to ping. This should make sure, that all nodes report an address that is reachable from the other system.
Originally posted by Ben_S with karma: 2510 on 2012-03-03
