Although it might not be very useful, when I select Raw view for an Image type topic in rxbag, I get a segfault.
Could somebody confirm this behaviour?
I'm using ros-electric on ubuntu oneiric. It's happened to me in two different PCs (laptop and desktop, with pretty different hardware but almost the same environment).
BTW, I'm using image_rect_color topics, from the image_pipeline stack, so images should be sane.
Thanks.
UPDATE Defect ticket created.
Originally posted by Enrique on ROS Answers with karma: 834 on 2012-02-28
Comment by joq on 2012-02-28:
For debugging a problem like this, a gdb stack backtrace of the segfault is usually needed.
Comment by Enrique on 2012-02-28:
How do I backtrace rxbag with gdb? I've tried https://wiki.ubuntu.com/Backtrace, but gdb says that rxbag is 'not in executable format: File format not recognized'. I just run 'gdb rxbag' (w/ and w/o args, a .bag file).
Comment by joq on 2012-02-29:
My mistake. I did not realize rxbag was a Python script.
Comment by Enrique on 2012-02-29:
So, how could I find out what's going on? Do you or somebody knows?
You can open a defect ticket, providing all the information you can for the rxbag maintainer.
Originally posted by joq with karma: 25443 on 2012-02-29
