Greetings, I'm trying to install gazebo and ROS at my Ubuntu 11.10, But I'm getting some errors after I try to run roslaunch gazebo_worlds empty_world.launch , this is what I get:
gazebo: /home/k/Programs/ogre_src_v1-7-4/OgreMain/include/OgreSingleton.h:80: Ogre::Singleton::Singleton() [with T = Ogre::TerrainPageSourceListenerManager]: Assertion `!ms_Singleton' failed. [gazebo-2] process has died [pid 13366, exit code -6]. log files: /home/k/.ros/log/87ad5d8a-600e-11e1-ab32-0024d690acd8/gazebo-2*.log
The above mentioned log does not exist in the given folder. :(
So I tried running gzserver and then gzclient, which rendered:
k@k-Inspiron-1545:~$ gzclient Gazebo multi-robot simulator, version 1.0.0-RC2 Copyright (C) 2011 Nate Koenig, John Hsu, Andrew Howard, and contributors. Released under the Apache 2 License. http://gazebosim.org
Msg Waiting for master Msg Connected to gazebo master @ http://localhost:11345 Qt: Session management error: None of the authentication protocols specified are supported Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'Ogre::ItemIdentityException' what(): OGRE EXCEPTION(5:ItemIdentityException): Can not find codec for 'png' image format. There are no formats supported (no codecs registered). in Codec::getCodec at /build/buildd/ogre-1.7.3/OgreMain/src/OgreCodec.cpp (line 69) Aborted k@k-Inspiron-1545:~$
But freeimage has been installed, shouldn't it be working?
Thanks in advance!
K
Originally posted by Kirus on ROS Answers with karma: 1 on 2012-02-25
This looks like a gazebo issue. I suggest you ask on http://answers.gazebosim.org
Originally posted by tfoote with karma: 58457 on 2013-08-09
