I'm using the Kinect for person tracking, and I have encountered a bug where OpenNI causes a segmentation fault when many objects move in/out of the frame. I did some research and it looks like the bug (below) was fixed in a newer version of OpenNI/NITE.
Program received signal SIGSEGV, Segmentation fault.
0x00007fffe23b374d in Segmentation::checkOcclusion(int, int, int, int) () from /usr/lib/libXnVFeatures.so
(gdb)
My question is, how can I safely update OpenNI to the latest version to work within the ROS framework?
Thanks for the help!
Originally posted by bkx on ROS Answers with karma: 145 on 2012-02-05
Well I'm not sure that I fixed the problem, but I haven't seen the segfault since updating to the latest stable OpenNI binaries here
Originally posted by bkx with karma: 145 on 2012-02-06
