I am attempting to install ROS Electric on an iMX53 Quick Start board running Lucid Linux 10.04. It is an ARM Cortex A8. I am following the directions for Lucid at http://www.ros.org/wiki/electric/Installation/Ubuntu. Everything goes well until:
"sudo apt-get install ros-electric-desktop-full"
returns: "E: Couldn't find package ros-electric-desktop-full"
Suggestions? My skill level is high and I have previously successfully installed Electric on Maverick on an x86.
Originally posted by StrongEnough on ROS Answers with karma: 11 on 2012-02-04
Comment by Stefan Kohlbrecher on 2012-02-04:
I'm not sure you can get Cortex A8 precompiled .debs. AFAIK, only i386 and amd64 are packaged right now. See also http://www.ros.org/debbuild/electric.html
Comment by joq on 2012-02-04:
I meant apt-get update, not upgrade.
Comment by StrongEnough on 2012-02-04:
I searched for this problem and saw nothing. Now, on the right, I see this issue http://answers.ros.org/question/1776/error-while-successful-sudo-apt-get-install-ros. Is it possible this is a mirror issue too? I'll look around for a way to change the mirror. I'm not a Linux expert yet.
Yes, You say "sudo apt-get upgrade" but I did "sudo apt-get update" per the instructions. Is that the problem? I don't have enough Karma to upload a screen shot, but in the Lucid "Software Sources, Other Software" tab; the item "http://packages.ros.org/ros/ubuntu lucid main" is checked.
Did you update the sources list? Is it correct? Did you apt-get upgrade?
You will have to build from source, see http://www.ros.org/wiki/electric/Installation/Ubuntu/Source
Originally posted by Kent Williams with karma: 91 on 2012-02-04
Comment by ahendrix on 2012-02-04:
Agreed. There are some debs available for ARM, but not nearly the full set that are available on x86. See http://ros.org/debbuild/electric.html for the current build status.
