In the first tutorial, for 'creating a urdf file'. On part 2 on creating the tree structure. I saved the xml as advised. Then 'rosmake urdf_parser' it compiles without any errors. Then after when i run the 'rosrun urdf_parser check_urdf my_urdf.xml' line.
the following error occurs :
Could not find the 'robot' element in the xml file
ERROR: Model Parsing the xml failed
If anyone has any ideas for what i could do, i would very grateful.
Originally posted by Patrick on ROS Answers with karma: 40 on 2012-02-02
3 Answers 3
Seems like your XML-file causes an error... is it the same one as in the tutorial?
Originally posted by michikarg with karma: 2108 on 2012-02-02
Thank you both for your help, ive updated my ubuntu and using a different text editor and the error does not appear.
Originally posted by Patrick with karma: 40 on 2012-02-06
Hi,
I had a similar problem like yours. I just gave the whole path of the file instead of just the file name and it worked fine.
Comment by karen0603 on 2014-03-12:
thanks, it works
