Hello,
I'm writing some automated test scripts. I'd like to run a launch script with a bag file, which works fine. But when the rosbag play completes I would like roslaunch to exit so my script can load up a new bag file and rerun roslaunch with the test.launch file. Is there an elegant way to cause all ros nodes and roscore to exit when a bag file is finished? I was thinking of making another script to monitor when rosbag finished and then execute a rosnode kill, but I thought there might be a better way.
Thanks, Jason
Originally posted by Jason LaPenta on ROS Answers with karma: 41 on 2012-01-25
Comment by kwc on 2012-01-25:
This is tangential, but you may want to look into using rostest to bring your test fixture up and down using roslaunch files
If you're running all your nodes from the same launch file as the bag, just add required="true" to the node tag for rosbag. This will cause the entire roslaunch to die when rosbag terminates.
Originally posted by Dan Lazewatsky with karma: 9115 on 2012-01-25
Post score: 9
Comment by tfoote on 2012-02-02:
When you get a good/the best answer please use the checkbox to the left to mark it as answered. I've done so for you this time.
Comment by Jason LaPenta on 2012-01-25:
this appears to work perfectly, thanks
Comment by Roger Yau on 2015-11-06:
typo: required = 'true'
I haven't tried this, but perhaps something like this:
rosbag play foo.bag; rosnode kill -a
Originally posted by JeffRousseau with karma: 1607 on 2012-01-25
Comment by fivef on 2014-10-22:
rosnode kill -a kind of works but sometimes not all nodes get killed
