Hi,
i am trying to use the openni skeleton tracker with kinect. We are starting openni with default parameters and openni_tracker:
$ roslaunch openni openni.launch
$ rosrun openni_tracker openni_tracker
And it basically seems to detect the human and the PSI-pose, but i cannot get any visualization in RVIZ. As far as i understand the code, the skeleton-transforms should be posted via tf? Also i cannot find the "Prime Sense User Tracker Viewer" anywhere...
Originally posted by michikarg on ROS Answers with karma: 2108 on 2012-01-19
what are your RVIZ configs ? you have to add a tf frame to rviz! Enter "rostopic list" command in console and make sure that tf topic is exist and also do a "rostopic echo /tf" to make sure that transforms are posted to tf topic! I think something similar to "Sense User Tracker Viewer" is exist in pi_tracker package!
Originally posted by Alireza with karma: 717 on 2012-01-19
Comment by michikarg on 2012-02-06:
Sorry for late, the pi_tracker worked for us!
Comment by michikarg on 2012-01-19:
Thanks for your answer. I already added tf to the RVIZ config and checked if the transforms are beiing sent with 'rostopic echo /tf', but only the camera frames appear... I will test with the pi_tracker package now...
/tf topics will be published when it has started tracking the User. Before 'tracking' you cannot visualize anything in the rviz. Just make sure you have added the TF and select /openni_depth_frame as Fixed/Reference frame .
Second option is to use the ros openni_tracker on offline data. Record a '.oni' file with Openni Sample NiViewer and then run the ros openni_tracker on this recorded data. For implementation details please checkout my post.
[http://tayyabnaseer.blogspot.de/2012/04/running-ros-openni-tracker-with.html]
Originally posted by tayyab with karma: 59 on 2012-04-23
