Hi,
I want to mount a Kinect on our Coppa Robot. I'm still new to ROS etc. so my question is: will it be "enough" to create a map of a building? If I understood it correctly, TurtleBot is doing that and a lot more using Kinect only? So I'd just have to use GMapping to create a map and later amcl to estimate the position? That's it? (sounds a bit too easy) ;)
Update: it is possible only if you have really good odometry. Without it you can forget it (amcl might still work but gmapping won't).
Originally posted by Cav on ROS Answers with karma: 345 on 2012-01-12
You'll need the pointcloud_to_laserscan and slam_gmapping packages to accomplish this. You should have a look at turtlebot_navigation gmapping_demo.launch as a good example of how to accomplish what you want. You can find additional help in a number of questions on this board, including here.
Originally posted by DimitriProsser with karma: 11163 on 2012-01-12
Post score: 4
Comment by Cav on 2012-01-12:
Great, now I just need to wait for the kinect to arrive :)
Comment by DimitriProsser on 2012-01-12:
I do believe so. I've never done it myself, but there's a lot of support for it on this forum.
Ok, thanks. So Kinect is enough to accomplish all of that?
For me the most tricky part turned out to be the odometry information passing. I took the base of this tutorial : http://www.ros.org/wiki/navigation/Tutorials/RobotSetup/Odom
Altered it a bit to fit my needs, but it mostly remained the same. If you need any more help, let me know ;)
Originally posted by Hansg91 with karma: 1909 on 2012-01-12
Comment by Cav on 2012-01-24:
Same here, odometry is a pain. My robot does not have a stepper motor and I don't know how to calculate the speed. In my case it's just a value between 0-100. The actual speed depends on many factors (battery state, ground, laptop weight, ...) so measuring it is pointless.Any Idea how to solve that?
Comment by joq on 2012-03-23:
A good Inertial Measurement Unit might help.
Comment by Cav on 2012-04-17:
A gyroscope and setting the speed to a fixed value helps a bit.
