#include <ros/ros.h>
#include <turtlesim/Pose.h>
#include <turtlesim/Velocity.h>
#include <cmath>
#include <math.h>
#include <angles/angles.h>
#include <std_msgs/Float64.h>
class TurtleControl
public:
TurtleControl(std::string name)
angle_sub = n.subscribe("set_angle", 1, &TurtleControl::setAngleCB, this);
distance_sub = n.subscribe("set_distance", 1, &TurtleControl::setDistanceCB, this);
sub = n.subscribe("/turtle1/pose", 1, &TurtleControl::turtlePoseCB, this);
pub = n.advertise<turtlesim::Velocity>("/turtle1/command_velocity", 1);
a_scale = 6.0;
l_scale = 6.0;
target_angle = 0.0;
target_distance = 0.0;
start_angle = 0;
error_tol = 0.00001;
start_x = 0;
start_y = 0;
~TurtleControl(void)
void setAngleCB(const std_msgs::Float64::ConstPtr& msg)
target_angle = msg->data;
void setDistanceCB(const std_msgs::Float64::ConstPtr& msg)
target_distance = msg->data;
new_distance_command = true;
void turtlePoseCB(const turtlesim::Pose::ConstPtr& msg)
if (new_distance_command)
start_x = msg->x;
start_y = msg->y;
new_distance_command= false;
theta_error = angles::normalize_angle_positive(target_angle - (msg->theta - start_angle));
distance_error = target_distance - fabs(sqrt((start_x- msg->x)*(start_x-msg->x) + (start_y-msg->y)*(start_y-msg->y)));
if (distance_error > error_tol)
command.linear = l_scale*distance_error;
command.angular = 0;
else if (distance_error < error_tol && fabs(theta_error)> error_tol)
command.angular = a_scale*theta_error;
command.linear = 0;
else if (distance_error < error_tol && fabs(theta_error)< error_tol)
command.linear = 0;
else
// publish the velocity command
pub.publish(command);
protected:
ros::NodeHandle n;
ros::Subscriber sub, angle_sub, distance_sub;
ros::Publisher pub;
turtlesim::Velocity command;
double a_scale ;
double l_scale ;
double target_angle;
double target_distance;
double start_angle;
double error_tol;
double theta_error;
double distance_error;
double start_x;
double start_y;
bool new_distance_command;
ros::init(argc, argv, "turtle_control");
TurtleControl turtle(ros::this_node::getName());
ros::spin();
return 0;
To set the target from the command line
rostopic pub set_angle std_msgs/Float64 3.14
or
rostopic pub set_distance std_msgs/Float64 2
Originally posted by mmwise with karma: 8372 on 2012-01-05
Post score: 5
Comment by Paul0nc on 2012-01-09:
I now have this working. Thanks mwise_wg for all your help!
Comment by Paul0nc on 2012-01-07:
Again, thanks. Sorry though, I'm not well versed or in this enough yet to understand what's going on in actionlib. How would I send the code you have above two different targets in succession programmatically (i.e. from main() ) ? I'm not sure how to wait for the first command to end.
Comment by mmwise on 2012-01-06:
this is similar to what I did in the actionlib example package. I have updated the code above to help you.
Comment by Paul0nc on 2012-01-06:
THANKS! This works great. A couple of follow up questions though: 1) Is there a corresponding linear controller (or did you write this just for my application)? and 2) How would I get this to execute more than once (to different angles)? Sorry for the newbie questions.
