I have added another source file in my package and run some commands like in the answer in this link (by running "make clean; make eclipse-project command and restart Eclipse"). However, the working package is not updated under eclipse.
I know that it will work out of the box, if I again go through the import package procedure, but, it is tiring doing it every time I add some new files in the package.
Is there any elegant way of doing it?
Originally posted by alfa_80 on ROS Answers with karma: 1053 on 2011-12-22
Comment by alfa_80 on 2011-12-22:
@DimitriProsser: There is no error but second source file that I've just added in the package is not updated in eclipse project tree. I simply cannot see it. Am I missing something?
Comment by DimitriProsser on 2011-12-22:
What are the errors that you're receiving?
Click on the Eclipse project tree for your package and press F5. This will update the Eclipse package manager.
Originally posted by DimitriProsser with karma: 11163 on 2011-12-22
By the way, just for sharing, I've press F5 before but not clicking to the "Eclipse project tree for your package" prior to press it. Luckily, got an eclipse expert like you here.
You really made my day :-) Thanks a lot for the fix!
Apart from the solution mentioned by Dimitri, it is also sometimes necessary to update Eclipse's index for the contextual help to work (right click on project -> Index -> Rebuild / Freshen with modified files / Freshen all files). Could help you some day too.
Originally posted by tom with karma: 1079 on 2011-12-22
Thanks for the sharing!
