I attempt to publish a topic/messages in a callback member function (refer here in the answers section), but, it doesn't work. The code is compiled without any complaints, however, when I issue a command to see the published message, say, ros echo -c /topic, it shows nothing there.
Is it not doable publishing it in the callback member function? Are there any alternatives to that?
Originally posted by alfa_80 on ROS Answers with karma: 1053 on 2011-12-14
Comment by Dan Lazewatsky on 2011-12-15:
Are you sure your callback is being called?
Yes it is doable.
Other than that, you will need to give more information.
Originally posted by dornhege with karma: 31395 on 2011-12-14
