Hi.. For following command: echo $ROS_PACKAGE_PATH
Output: /opt/ros/electric/stacks
Change directory: cd ~/ros_workspace
Then: roscreate-pkg beginner_tutorials std_msgs rospy roscpp
WARNING: current working directory is not on ROS_PACKAGE_PATH! Please update your ROS_PACKAGE_PATH environment variable. I don't know why??
How do I change it? I follow all the instruction in previous section of setting environmental variable where I get proper output as mentioned. But i think there is still something very basic going wrong, which I am not able to figure out..because I am new at Ubuntu.
After package is created, when i try to find: rospack find beginner_tutorials
message : rospack couldn't find beginner_tutorials.
I am getting this error from long time..and not able to find the solution!! Please help. Is it possible for real time help?(on gmail, yahoo, skype..etc)
Thank you. Regards.
Originally posted by dbs12 on ROS Answers with karma: 26 on 2011-12-09
You need to add your ros_workspace to your ROS_PACKAGE_PATH. This can be done in your bashrc file. For a short, one-line solution enter the following into the commandline:
echo -e "\nexport ROS_PACKAGE_PATH=~/ros_workspace:$ROS_PACKAGE_PATH\n" >> ~/.bashrc
Then, in order to see the changes, you must remember to source your bashrc. (This only needs to be done on any terminals already open. Any new terminals you open henceforth will already be all set.)
source ~/.bashrc
Originally posted by DimitriProsser with karma: 11163 on 2011-12-09
