hi all, i can't install the stack ccny_vision. i'm following the instruction, but i have some errors when i run
rosmake ccny_vision --rosdep-install.
i solved the first one with:
Run the following commands to remove the offending line:
roscd ccny_vision sed -i '/ubuntu: libglut3-dev/d' rosdep.yamllibglut3-dev/d' rosdep.yaml
but when i build the ccny_vision stack:
rosmake/rosmake_output-20111206-162013
rosmake/rosmake_output-20111206-162013> mkdir -p build mkdir: impossibile
creare la directory "build": Permesso negato make: [build/artoolkit/unpacked] Errore 1 (ignorato) if [ ! -f ARToolKit-SVN-r311.tar.gz.md5sum ]; then echo "Error: Couldn't find md5sum file ARToolKit-SVN-r311.tar.gz.md5sum" && false; fi rospack find rosbuild/bin/download_checkmd5.py https://code.ros.org/svn/release/download/thirdparty/ARToolKit-SVN-r311.tar.gz build/ARToolKit-SVN-r311.tar.gz awk {'print $1'} ARToolKit-SVN-r311.tar.gz.md5sum
Traceback (most recent call last): File "/opt/ros/electric/ros/core/rosbuild/bin/download_checkmd5.py", line 56, in sys.exit(main()) File "/opt/ros/electric/ros/core/rosbuild/bin/download_checkmd5.py", line 22, in main os.makedirs(d) File "/usr/lib/python2.7/os.py", line 157, in makedirs mkdir(name, mode) OSError: [Errno 13] Permission denied: 'build' -------------------------------------------------------------------------------} [ rosmake ] Output from build of package artoolkit written to: [ rosmake ]
/home/mauro/.ros/rosmake/rosmake_output-20111206-162013/artoolkit/build_output.log [rosmake-1] Finished <<< artoolkit [FAIL] [ 0.09 seconds ]
[rosmake-0] Starting >>> nav_msgs [ make ]
[rosmake-0] Finished <<< nav_msgs ROS_NOBUILD in package nav_msgs
[rosmake-0] Starting >>> diagnostic_msgs [ make ]
[rosmake-0] Finished <<< diagnostic_msgs ROS_NOBUILD in package diagnostic_msgs
[rosmake-0] Starting >>> test_common_msgs [ make ]
[ rosmake ] Halting due to failure in package artoolkit. [ rosmake ] Waiting for other threads to complete. [rosmake-0] Finished <<< test_common_msgs ROS_NOBUILD in package test_common_msgs
[ rosmake ] Results:
[ rosmake ] Built 63 packages with 1 failures.
[ rosmake ] Summary output to directory
[ rosmake ] /home/mauro/.ros/rosmake/rosmake_output-20111206-162013rosmake/rosmake_output-20111206-162013 rosmake/rosmake_output-20111206-162013
Originally posted by Maurizio88 on ROS Answers with karma: 155 on 2011-12-06
Comment by karthik on 2011-12-06:
where is the folder ccny_vision downloaded to... path?
Comment by ayush_dewan on 2012-05-13:
What is the solution to this problem, I am having the same error..
You are trying to create a directory in the /opt/ros/electric/ros/core path.
You will not have permission to create something in that place. If you still want to do it. You can change the permission of the ccny_vision folder with write access. I suggest you to have a ros_workspace created as given in the below page
http://www.ros.org/wiki/ROS/Tutorials/InstallingandConfiguringROSEnvironment
and use the same path for the future packages that you download and install. In this particular case, just have this workspace created and setup the environment. Paste your ccny_vision folder there and try to execute your commands.
Hope this helps, Karthik
Originally posted by karthik with karma: 2831 on 2011-12-06
