Hello,
due to the recent change in Bullet[1], I have to patch my stack when releasing for unstable but not when releasing for Electric. The SCM I use for this stack is Git.
Then problem is that even if create.py maintains different branches for each ROS version (unstable and electric in my case), it always update them using the current state of the master branch.
What I would like to do in this case is comitting myself on unstable to handle [1]. Then I would like create.py to use the current state of the unstable branch to create the release.
Is it possible to do so? Is there something I am missing?
Thanks!
[1] ros-users Bullet change in unstable for Fuerte
Originally posted by Thomas on ROS Answers with karma: 4478 on 2011-12-04
The create.py updates the branch defined in the rosdistro file. If you change the definition in the rosdistro file for each release it will pull from a different branch for the specified release.
For example in electric.rosdistro define the dev-branch to be electric-devel and the unstable.rosdistro file define the dev-branch to be master, etc.
Originally posted by tfoote with karma: 58457 on 2012-04-09
Comment by joq on 2012-04-10:
While releasing from a different branch for each distro is the "standard" ROS solution, that is not what external groups like ours want. We need our development trunk to work with two successive distros. Generally, tick-tock makes that possible, though it often means slower adoption of new features.
Partial answer:
I had a similar problem for geographic_info. While I strongly prefer to maintain support for both distributions in a single source tree, ROS does not make that easy.
In my case, the cleanest solution was to drop the direct dependency on bullet, and use the equivalent tf types instead. That may not work for everyone.
If the tf types do not meet your needs, it might help for your C++ code to query the ROS version using pre-processor tests. Unfortunately, I know of no way to hide the bullet dependency differences in manifest.xml. As a tick-tock measure, maybe we should keep an empty bullet package around for Fuerte with just a rosdep for the system library.
Originally posted by joq with karma: 25443 on 2011-12-05
Comment by joq on 2011-12-07:
Well, I guess that's why we call it "unstable". :-)
Comment by Thomas on 2011-12-06:
I just noticed that unfortunately this version number is currently broken in unstable, see https://code.ros.org/trac/ros/ticket/3782
Comment by Thomas on 2011-12-05:
Thanks, this is an interesting workaround, I will try that :)
