Hi:
I having trouble getting rosmake to compile with the new version of opencv. I keep getting "fatal error: opencv-2.3.1/opencv2/features2d/features2d.h: No such file or directory compilation terminated."
I don't remember personally installing opencv, it must have come up with something else, perhaps (ROS-Electric). But anyway, I have the *.so.2.3.1 libraries in the /usr/lib folder and the include directory in /usr/include/opencv-2.3.1/opencv2/.... I set the C_PATH_INCLUDE and CPLUS_PATH_INCLUDE variables to the 2.3.1 directory and yet it still can't find the .h files.
What else is required so my package can see it? I think Cmakelists.txt only has the Find_Package(OpenCv) which only finds the old opencv and not the 2.3.1 version. I need it to be this version so I can use the simple blob detection api. Any help is appreciated.
Thanks in advance.
Originally posted by asrinivasan31 on ROS Answers with karma: 51 on 2011-12-02
It would be helpful if you gave more information ... operating system, version of ROS, etc.
OpenCV is an external library in Electric (which I am guessing you are using). Try installing the library. On the Mac using homebrew do: brew install opencv.
In my CMakeLists.txt file to build a fictional program called test, I have the following:
find_package(OpenCV 2.3.1 REQUIRED)
rosbuild_add_executable(test src/test.cpp )
target_link_libraries(test ${OpenCV_LIBS})
If you are not sure which opencv cmake is finding, you can do something like this to the CMakeLists.txt:
if(OpenCV_FOUND)
     message("====== Found ${OpenCV_VERSION} =======")
endif(OpenCV_FOUND)
Hope that helps!
Originally posted by Kevin with karma: 2962 on 2011-12-04
