Hi, I want to migrate my joystick programs from deprecated joystick_drivers to sensor_msgs equivalent.
When I used joystick_drivers I run an executable joy_node..., then a node "joy_node" was created to publish the Joy msg (I just suscribe to it and was simple)...
but... with sensor_msgs equivalent, I don't know what executable do I have to run to see a publisher node giving me the Joy msgs... I have tried the following simple listener..., but I simply can't see anybody (with rostopic & rxgraph) publishing Joy msgs...
Thanks for your help!
#include <ros/ros.h>
#include <sensor_msgs/Joy.h>
void myCallback (const sensor_msgs::Joy::ConstPtr& msg)
  for (unsigned i = 0; i < msg->axes.size(); ++i) {
    ROS_INFO("Axis %d is now at position %f", i, msg->axes[i]);
  ros::init(argc, argv, "listener");
  ros::NodeHandle n;
  ros::Subscriber sub = n.subscribe("joy", 1000, myCallback);
  ros::spin();
  return 0;
Originally posted by marcobecerrap on ROS Answers with karma: 107 on 2011-12-01
See http://www.ros.org/wiki/joy/Tutorials/ConfiguringALinuxJoystick#Starting_the_Joy_Node.
Originally posted by jbohren with karma: 5809 on 2011-12-01
Comment by marcobecerrap on 2011-12-01:
Thanks for your help, I have realized that there is no way to avoid installing "joystick_drivers". Because, some sensor msgs has their own manipulation stacks (i.e. Joy needs "joystick_drivers" stack). The correct way is to install the missing stack; thanks a lot! PS. The code is correct.
