Hi everyone,
I have installed ROS electric recently. I try to get point cloud from the Kinect sensor by the following command:
$ roslaunch openni_launch openni.launch
It runs a few couple of nodelets and warns about the calibration .yaml files which seems to be OK. I can see a list of topics that it advertises, but neither "rviz" nor "rostopic hz" can capture any data from any topic starting with "/camera"!
However, with the following command:
$ roslaunch openni_camera openni_node.laucnh
I can capture point clouds streaming out from the Kinect sensor. Any idea why openni_launch doesn't publish any data on the topics?
Best, Rasoul
Originally posted by Rasoul on ROS Answers with karma: 115 on 2011-11-30
You might have a look at this answer by Patrick Mihelich. Maybe compiling the latest version from svn helps for you too. Sometimes the openni.launch works if you restart it a lot. I were having similar problems and spent a lot time on continuous restarting until i got output from rostopic hz...
Finally i did a clean reinstall and switched to 64 bit Ubuntu which helped a lot (at least for me).
Originally posted by Ben_S with karma: 2510 on 2011-12-01
Comment by karthik on 2011-12-14:
Hi, same issue here. Pointclouds are published and can see them when echoed topic wise. but not visible in rviz. can the reinstall b done using synaptic or should i remove n do it through svn?
Comment by Ben_S on 2011-12-01:
Im glad that i could help you. Could you please accept my answer, so that its clear, that the problem is solved? Thanks a lot. :)
Comment by Rasoul on 2011-12-01:
By compiling the latest version from svn, it started working properly. Thank you very much for your help!
