I am trying to run gmapping_slam on some old data to improve the position estimate and during my use of the resulting /map -> /odom I realized the stamp on the transforms were using the current walltime rather than the simulated time.
So I setup an experiment to narrow down the cause of this.
I created two simple examples using ros Time in c++ and python:
Python:
#!/usr/bin/env python
import roslib; roslib.load_manifest('time_example')
import rospy
def main():
    rospy.init_node('time_exmaple')
    r = rospy.Rate(5)
        rospy.loginfo("The time is: %f" % rospy.Time.now().to_sec())
        r.sleep()
if __name__ == '__main__':
    main()
C++:
#include "ros/ros.h"
int main(int argc, char **argv) {
  ros::init(argc, argv, "teleop_server");
  ros::NodeHandle n;
  ros::Rate r (5);
  while (ros::ok()) {
    ROS_INFO("The time is: %f", ros::Time::now().toSec());
    ros::spinOnce();
    r.sleep();
Then I created a roscore instance:
∫ roscore
... logging to /home/william/.ros/log/1bd2d176-1bd5-11e1-a585-002564acbaae/roslaunch-GDRS-Workstation-16779.log
Press Ctrl-C to interrupt
started roslaunch server http://GDRS-Workstation:53680/
ros_comm version 1.6.5
SUMMARY
PARAMETERS
 * /rosversion
 * /rosdistro
NODES
auto-starting new master
process[master]: started with pid [16794]
ROS_MASTER_URI=http://GDRS-Workstation:11311/
setting /run_id to 1bd2d176-1bd5-11e1-a585-002564acbaae
process[rosout-1]: started with pid [16807]
started core service [/rosout]
And then in a new terminal I set the use_sim_time parameter with rosparam:
∫ rosparam set use_sim_time 1
In the same terminal I started a bag file I am using.
∫ rosbag play --clock gavlab_and_hallway_2011-04-17-15-09-47.bag
[ INFO] [1322715599.665805485]: Opening gavlab_and_hallway_2011-04-17-15-09-47.bag
Waiting 0.2 seconds after advertising topics... done.
Hit space to toggle paused, or 's' to step.
 [RUNNING]  Bag Time: 1303070993.265138   Duration: 5.743087 / 715.993344
In a new terminal I ran the Python and then the C++ code:
∫ python nodes/time_example.py
[INFO] [WallTime: 1322714195.471402] [0.000000] The time is: 0.000000
[INFO] [WallTime: 1322714195.857057] [1303071368.690635] The time is: 1303071368.690635
[INFO] [WallTime: 1322714195.857385] [1303071368.690635] The time is: 1303071368.690635
[INFO] [WallTime: 1322714196.055195] [1303071368.892812] The time is: 1303071368.892812
... SHORTENED MANUALLY
[INFO] [WallTime: 1322714211.060998] [1303071383.899060] The time is: 1303071383.899060
[INFO] [WallTime: 1322714211.257225] [1303071384.091894] The time is: 1303071384.091894
[INFO] [WallTime: 1322714211.453530] [1303071384.294445] The time is: 1303071384.294445
^CTraceback (most recent call last):
  File "nodes/time_example.py", line 15, in <module>
    main()
  File "nodes/time_example.py", line 12, in main
    r.sleep()
  File "/opt/ros/electric/stacks/ros_comm/clients/rospy/src/rospy/timer.py", line 77, in sleep
    sleep(self.sleep_dur - elapsed)
  File "/opt/ros/electric/stacks/ros_comm/clients/rospy/src/rospy/timer.py", line 132, in sleep
    raise rospy.exceptions.ROSInterruptException("ROS shutdown request")
rospy.exceptions.ROSInterruptException: ROS shutdown request
∫ bin/time_example
[ INFO] [1322714223.326848478]: The time is: 1322714223.326797
[ INFO] [1322714223.526966411]: The time is: 1322714223.526938
[ INFO] [1322714223.726959496]: The time is: 1322714223.726931
[ INFO] [1322714223.926960677]: The time is: 1322714223.926931
[ INFO] [1322714231.126978724]: The time is: 1322714231.126951
[ INFO] [1322714231.326972936]: The time is: 1322714231.326946
[ INFO] [1322714231.527002318]: The time is: 1322714231.526975
[ INFO] [1322714231.726982139]: The time is: 1322714231.726955
As you can see the Python node is reporting the correct simulated time, and sees the initial time of 0 during the clock initialization period, but the C++ node is reporting the wall time rather than the sim time.
Am I missing something here? Is there another step to make C++ respect the use_sim_time setting?
I am using the latest ROS electric debs on Ubuntu 11.10 x86_64 and I can confirm this is happening on my MacbookPro running the Homebrew based ROS electric source install.
Thanks in advance.
Originally posted by William on ROS Answers with karma: 17335 on 2011-11-30
So, Python will work with rosparam set use_sim_time 1 but C++ needs rosparam set use_sim_time true. Maybe there should be a warning about this on the wiki or at run time.
Originally posted by William with karma: 17335 on 2011-11-30
Post score: 4
Comment by Mac on 2011-11-30:
That has got to be a bug. If it isn't a bug, it should be. If it shouldn't be a bug, then I need be surgically altered to believe that. I'd open a ticket.
Comment by Dave Coleman on 2014-05-27:
This got me just now, too. Was a ticket ever made?
Comment by William on 2014-05-28:
I guess not, it was before github.
Comment by Dave Coleman on 2014-06-09:
I created a ticket here https://github.com/ros/ros_comm/issues/436
