Guys, I have a problem with the following tutorial: http://www.ros.org/wiki/motion_planning_environment/Tutorials/Tutorial%20A when I call roslaunch pr2_arm_navigation_tutorials laser-perception.launch the collision map does not show on rviz. Instead I get the following message:
[ WARN] [1322669029.655800639]: You've passed in true for auto_start for the C++ action server you should always pass in false to avoid race conditions. [laser_clear_objects-5] process has died [pid 16360, exit code -6].
What is the problem? Thanks
Originally posted by zamboni on ROS Answers with karma: 11 on 2011-11-30
That tutorial only works for Diamondback - I added a note to that effect at the top of the tutorial. For a roughly equivalent Electric tutorial use this one: Checking State Validity
Originally posted by egiljones with karma: 2031 on 2011-11-30
