Hi everyone!
I downloaded the gazebo development version and I'm working on it. How can I create a diff file of all gazebo package (including the sourcecode) to see my changes and easily make a patch??
I downloaded the simulator gazebo from: svn co https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/branches/simulator_gazebo-1.2 ~/simulator_gazebo/
Added the new simulator gazebo path to ROS_PACKAGE_PATH and build. It takes like 700 seconds and then all is OK, in build folder is all the source code.
If I do a "svn st" all the folders are with a "?" If I do a svn info it returns:
Path: . URL: https://code.ros.org/svn/ros-pkg/stacks/simulator_gazebo/branches/simulator_gazebo-1.2/gazebo Repository Root: https://code.ros.org/svn/ros-pkg Repository UUID: eb33c2ac-9c88-4c90-87e0-44a10359b0c3 Revision: 38270
Node Kind: directory Schedule: normal
Last Changed Author: hsu
Last Changed Rev: 37935
Last Changed Date: 2011-09-16 22:44:55 +0200 (Fri, 16 Sep 2011)
And if I do a svn diff it don't return anything (even if a made some changes in the source code). What am I doing wrong? or what is the proper way of do it?
Originally posted by jrcapriles on ROS Answers with karma: 370 on 2011-11-23
I already found the answer to my own question, when you are working with development versions, the source code package is donwloaded when you do a rosmake, in my case if you go to simulator_gazebo/gazebo folder, it should be a "Makefile.gazebo.trunk" this file contain all the information required to building the code. There is the location of the source code repository. In my case is in:
SVN_URL = https://playerstage.svn.sourceforge.net/svnroot/playerstage/code/gazebo/trunk
You can do a "svn co" of this repository, add your changes and then do a "svn diff", this will return you a patch file from gazebo source code. I did this to attach this patch to a gazebo defect ticket with IRSensor https://kforge.ros.org/gazebo/trac/ticket/30
Originally posted by jrcapriles with karma: 370 on 2011-11-24
