I am looking for a way to restrict a robot's range of motion, using complex constraints such as not tearing of a cable attached to the robot.
Take an articulated 6-axis robot arm as shown below, with attached cable (red), fixed at points X (before axis A4) and Y (after axis A6).
The cable will limit the range of movement for the robot. It can stretch and bend only to some extend, but something like a full 360° turn of axis A4, with all other axes remaining as they are in the picture, will tie the cable around the arm and rip it off.
If joint A5 is at 0°, then A4 and A6 can still move the full 360°, but they cannot diverge too much from each other, as that would twist the cable. If A5 is tilted, the relationship becomes even more complicated.
How can you express such a constraint?
It is not a simple joint constraint, where you can independently limit the range of the joints, and it is also not a positional constraint, where you can define a region the robot must not enter. Checking a start and a goal posture is not sufficient, since along the path from start to goal posture there may still be a posture that puts too much strain on the cable.
Without limiting the robot to a small set of pre-tested paths, how can you limit the robot to movements that will not rip off the cable?
What are the standard techniques used for this sort of problem?
