Hi, there, I'm trying to connect Kinect with turtlebot, but it is not working. First of all, I was following instructions on how to "hack" kinect cable and connect it with power board which has gyro. I cut power cable as it was shown and made an adapter to connect with power board. Then, I've connected Kinect with my TrimSlice - I see green light on Kinect start blinking. I've plugged second cable into the power board and run: roslaunch turtlebot_calibration calibrate.launch After all processes has started I consistently see:
[INFO] [WallTime: 1321466338.673699] Still waiting for scan [INFO] [WallTime: 1321466338.975991] Still waiting for scan [INFO] [WallTime: 1321466339.277746] Still waiting for scan [INFO] [WallTime: 1321466339.580285] Still waiting for scan [ INFO] [1321466339.599740633]: [/openni_camera] No devices connected.... waiting for devices to be connected ...
Ctrl+C doesn't stop this process and I would have this output unless I will kill this process.
I was searching by error in google and here but didn't get anything which I could apply to my situation. Most of the questions about Kinect related to it work when I can't even start it. Any ideas what I was doing wrong or/and how I can fix it? Thanks. -Roman.
Originally posted by Roman Burdakov on ROS Answers with karma: 131 on 2011-11-16
Comment by Roman Burdakov on 2011-11-21:
I don't know how but it finaly got through. I was trying many different things and appently one of them has worked. Now I'm getting different errors but this is a subject for a separate topic. Thanks!
Comment by mmwise on 2011-11-16:
can you view images out of the kinect? that would be the first thing to check. when the calibration says waiting for scan, a scan is not being published which could mean in turn that a pointcloud isn't being published.
Originally posted by mmwise with karma: 8372 on 2012-02-16
