I am trying to compile a program I have that uses opencv, and I get the following error:
--> Making UTIL -- Linking popup.o to popup (C++) /usr/bin/ld: cannot find -l/usr/lib/libopencv_contrib.so.2.3.1 collect2: ld returned 1 exit status make[2]: *** [popup] Error 1 make[1]: *** [binaries] Error 255 make: *** [all] Error 2
However, I do seem to have the necessary files:
/usr/lib$ ls -l
lrwxrwxrwx 1 root root 24 2011-11-13 09:20 libopencv_contrib.so -> libopencv_contrib.so.2.3
lrwxrwxrwx 1 root root 26 2011-11-13 09:20 libopencv_contrib.so.2.3 -> libopencv_contrib.so.2.3.1
-rw-r--r-- 1 root root 372344 2011-11-11 00:12 libopencv_contrib.so.2.3.1
I also have $LD_LIBRARY_PATH set as follows
$echo $LD_LIBRARY_PATH
/usr/lib
The library is being searched for because I am trying to link to opencv2, in which the manifest at /opt/ros/electric/stacks/vision_opencv/opencv2/manifest.xml has:
<\export>
<\cpp cflags="pkg-config opencv-2.3.1 --cflags
" lflags="pkg-config opencv-2.3.1 --libs
And this command returns: $pkg-config opencv-2.3.1 --libs
-l/usr/lib/libopencv_contrib.so.2.3.1 -l/usr/lib/libopencv_legacy.so.2.3.1 -l/usr/lib/libopencv_objdetect.so.2.3.1 -l/usr/lib/libopencv_calib3d.so.2.3.1 -l/usr/lib/libopencv_features2d.so.2.3.1 -l/usr/lib/libopencv_video.so.2.3.1 -l/usr/lib/libopencv_highgui.so.2.3.1 -l/usr/lib/libopencv_ml.so.2.3.1 -l/usr/lib/libopencv_imgproc.so.2.3.1 -l/usr/lib/libopencv_flann.so.2.3.1 -l/usr/lib/libopencv_core.so.2.3.1
I am using Ubuntu 10.04.3 LTS (Lucid). I also just switched from diamondback to electric, which was installed using "sudo apt-get install ros-electric-desktop-full".
Any advice would be appreciated. If this is not the appropriate place to ask this question, I apologize, and please direct me to the appropriate place. Also, if I have not provided sufficient information or explained my question in enough detail, please let me know what additional information I can provide.
Thanks!
Originally posted by davheld on ROS Answers with karma: 3 on 2011-11-13
