i'm trying to run 'bag_to_pcd' from the terminal but keep getting the following error..
[ERROR] [1320830633.224372085]: [registerPublisher] Failed to contact master at [localhost:11311]. Retrying...
rosrun pcl_ros bag_to-pcd points2.bag /camera/depth/points2 mr
where,
- points2.bag is my bag file
- /camera/depth/points2 is the topic
- mr is the directory where to put the pcd files
if i ctrl c out of it, the following comes up...
^Cterminate called after throwing an instance of 'ros::TimeNotInitializedException'
what(): Cannot use ros::Time::now() before the first NodeHandle has been created or ros::start() has been called. If this is a standalone app or test that just uses ros::Time and does not communicate over ROS, you may also call ros::Time::init()
Aborted
and rosbag info points2.bag gives me...
path: points2.bag
version: 2.0
duration: 8.6s
start: Nov 08 2011 15:23:14.96 (1320762194.96)
end: Nov 08 2011 15:23:23.58 (1320762203.58)
compression: none [143/143 chunks]
types: sensor_msgs/PointCloud2 [1158d486dd51d683ce2f1be655c3c181]
topics: /camera/depth/points2 428 msgs : sensor_msgs/PointCloud2
thanks for reading!
Originally posted by liquidmonkey on ROS Answers with karma: 37 on 2011-11-08
