On the rviz wiki, one of the command line arguments is listed as :
-d, --display-config <arg>
Load configuration file <arg> at startup.
What is the format for rviz configuration files, to feed rviz at the command line?
Originally posted by j-v on ROS Answers with karma: 23 on 2011-11-07
The easiest way to edit rviz configurations is through rviz itself:
  • Open rviz and set up whatever displays and layout you like.
  • Go to File->Save Config and choose a descriptive file name.
Later, you can restore your configuration by running rviz with -d, or with File->Open Config. rviz also maintains a list of File->Recent Configs for you. Saving your config is useful when you have a specific desired layout for an application or demo.
For day-to-day use, rviz stores your current config in $HOME/.rviz/display_config, so you can close and re-open rviz without losing your displays and layout.
In general there's no need to edit .vcg files by hand, but they are in a simple INI format. Save one out and open it in your favorite text editor to see the details.
Originally posted by Patrick Mihelich with karma: 4336 on 2011-11-07
Post score: 10
