Hi,
Is there any working service server/client example code like the AddTwoInts tutorial for rospy and roscpp? I am able to run publisher/subscriber in rosjava, but struggling making a rosjava service server node works.
What I am trying is a simple service server which takes empty request and print something on the screen.
import com.google.common.base.Preconditions;
import org.ros.node.DefaultNodeFactory;
import org.ros.node.Node;
import org.ros.node.NodeConfiguration;
import org.ros.node.NodeMain;
import org.ros.node.service.ServiceServer;
import org.ros.internal.node.service.ServiceResponseBuilder;
import org.ros.service.std_srvs.Empty;
public class TestServiceServer implements NodeMain {
  private static final String SERVICE_NAME = "/test_service";
  private static final String SERVICE_TYPE = "std_srvs/Empty";
  private Node node;
  @Override
  public void main(NodeConfiguration configuration) {
    Preconditions.checkState(node == null);
    Preconditions.checkNotNull(configuration);
    try {
      System.out.println("Starting a Testing Service Node........");
      node = new DefaultNodeFactory().newNode("test_service_server", configuration);
      ServiceServer<Empty.Request, Empty.Response> server =
          node.newServiceServer(SERVICE_NAME, SERVICE_TYPE,
              new ServiceResponseBuilder<Empty.Request, Empty.Response>() {
                @Override
                public Empty.Response build(Empty.Request request) {
                  Empty.Response response = new Empty.Response();
                  System.out.println("called!!");
                  return response;
      //server.awaitRegistration();
    } catch (Exception e) {
      if (node != null) {
        node.getLog().fatal(e);
      } else {
        e.printStackTrace();
  @Override
  public void shutdown() {
    node.shutdown();
    node = null;
When I call the service:
rosservice call /test_service
These error shows up:
  File "/opt/ros/electric/ros/bin/rosservice", line 46, in <module>
    rosservice.rosservicemain()
  File "/opt/ros/electric/stacks/ros_comm/tools/rosservice/src/rosservice.py", line     731, in rosservicemain
    _rosservice_cmd_call(argv)
  File "/opt/ros/electric/stacks/ros_comm/tools/rosservice/src/rosservice.py", line  586, in _rosservice_cmd_call
    service_class = get_service_class_by_name(service_name)
  File "/opt/ros/electric/stacks/ros_comm/tools/rosservice/src/rosservice.py", line   357, in get_service_class_by_name
    service_type = get_service_type(service_name)
  File "/opt/ros/electric/stacks/ros_comm/tools/rosservice/src/rosservice.py", line 141, in get_service_type
    return get_service_headers(service_name, service_uri).get('type', None)
  File "/opt/ros/electric/stacks/ros_comm/tools/rosservice/src/rosservice.py", line  113, in get_service_headers
    return roslib.network.read_ros_handshake_header(s, cStringIO.StringIO(), 2048)
  File "/opt/ros/electric/ros/core/roslib/src/roslib/network.py", line 367, in   read_ros_handshake_header
    raise ROSHandshakeException("connection from sender terminated before handshake    header received. %s bytes were received. Please check sender for additional   details."%b.tell())
roslib.network.ROSHandshakeException: connection from sender terminated before    handshake header received. 0 bytes were received. Please check sender for additional  details.
Could someone point what's the problem? Thanks.
Originally posted by Liang-Ting Jiang on ROS Answers with karma: 21 on 2011-11-01
Looks like services seem to be working with a current (11/23) checkout, I just ran the AddTwoInts test with a python service and a java client (code below). I followed the setup howto here.
import org.apache.commons.logging.Log;
import org.ros.exception.RemoteException;
import org.ros.node.service.ServiceClient;
import org.ros.node.service.ServiceResponseListener;
import org.ros.service.test_ros.AddTwoInts;
public class TestService implements NodeMain {
private Node node;
private static final String SERVICE_NAME = "/add_two_ints";
private static final String SERVICE_TYPE = "test_ros/AddTwoInts";
@Override
public void main(Node node) {
    Preconditions.checkState(this.node == null);
    this.node = node;
    try {
        final Log log = node.getLog();
        ServiceClient<AddTwoInts.Request, AddTwoInts.Response> client =
            node.newServiceClient(SERVICE_NAME, SERVICE_TYPE);
        // TODO(damonkohler): This is a hack that we should remove once it's
        // possible to block on a connection being established.
        Thread.sleep(100);
        AddTwoInts.Request request = new AddTwoInts.Request();
        request.a = 2;
        request.b = 2;
        client.call(request, new ServiceResponseListener<AddTwoInts.Response>() {
            @Override
            public void onSuccess(AddTwoInts.Response message) {
                log.info("I added 2 + 2: " + message.sum);
            @Override
            public void onFailure(RemoteException arg0) {
                log.info("I failed to add 2 + 2");
        if (node != null) {
        } else {
@Override
    node.shutdown();
    node = null;
Originally posted by JeffRousseau with karma: 1607 on 2011-11-23
