Hi! im using ROS Electric installed from sources and OpenCV from svn and its has version 2.3.2 but if im trying to make cv_bridge
rosmake cv_bridge
it want to use 2.3.1:
Package opencv-2.3.1 was not found in the pkg-config search path.
How could i use OpenCV 2.3.2 instead of 2.3.1? Thanks!
Originally posted by noonv on ROS Answers with karma: 471 on 2011-10-30
One way that works for me consists in:
  1. Copying the ROS OpenCV package somewhere. You may renamed this new package to something like opencv232.
  2. Changing the Makefile so it downloads the last svn version.
  3. Then rosmake -i (remove ROS_NOBUILD fisrt).
For cv_bridge:
  1. Copy cv_bridge
  2. Rename (opcional)
  3. Change manifest dependency to opencv232
  4. rosmake -i
Maybe not so clean, but it works.
Originally posted by Enrique with karma: 834 on 2011-11-01
Comment by noonv on 2011-11-01:
Thanks a lot!
this answer help me:
Sometimes the ROS package might be looking for a particular .pc filename, like "opencv-2.3.pc", when your build of opencv 2.3 only placed a "opencv.pc" file there. Then, my solution is to create a symbolic link, in this case from "opencv.pc" to "opencv-2.3.pc" in the relevant pkgconfig path.
my actions:
sudo cp /usr/local/lib/pkgconfig/opencv.pc /usr/local/lib/pkgconfig/opencv-2.3.1.pc
edit opencv-2.3.1.pc and change 2.3.2 on 2.3.1
check:
pkg-config opencv-2.3.1 --cflags
pkg-config opencv-2.3.1 --libs
and
rosmake cv_bridge
it make ok, but with warning:
[ rosmake ] WARNING: Rosdep did not detect the following system dependencies as installed: opencv2.3 Consider using --rosdep-install option or rosdep install c v_bridge
Originally posted by noonv with karma: 471 on 2011-11-01
