Hello eveyone!
We installed rosjava and we want to publish and subscribe messages between a PC and an android-phone.
  • roscore is running on the PC
  • there is a publisher and a subscriber on the phone and/or pc
  • ROS_MASTER_URI is set on the phone to the PC's IP
This works:
  • subscribe messages on the phone, which were published on the phone
  • subscribe messages on the phone, which were published on the PC
  • subscribe messages on the PC, which were published on the PC
This does not work:
  • subscribe messages on the PC, which were published on the phone
Our guess: We think that the phone sends a wrong name ("127.0.0.1") of itself to the core:
  • rxgraph shows for the phone-publisher: "ERROR: Communication with node[http://127.0.0.1:55124] failed!
  • rxgraph shows for the phone-subscriber: "ERROR: Communication with node[http://127.0.0.1:40919] failed!
-> We already tried to change the phone's name via setprop net.hostname (which changes net.hostname, but does not change the situation at all) -> We tried to define the name in the phones /etc/hosts file; with no result
What are we doing wrong?
Originally posted by gimili on ROS Answers with karma: 3 on 2011-10-27
This is probably not your answer but is similiar in that sometimes communication will fail if you're not tethering with USB because of the line
NodeConfiguration.newPublic(InetAddressFactory.newNonLoopback().getHostName());
You need to change it to get an IP address, not a host name. Otherwise, external devices will have a difficult time resolving the Android hostname if the Android device is not doing the DNS lookups for it.
Originally posted by Chad Rockey with karma: 4541 on 2011-10-27
Comment by gimili on 2011-10-27:
Thank you; this works! We were so blinded by getting the IP responding to the hostname and dns settings that we did not see the "newPrivate" in our code we used from the pubsubtutorial, where everything runs on the phone!
Use a NonLoopback server address when you create one. You could use something like
Roscore _core = RosCore.newPublic(11411);
Originally posted by ICodeRaven with karma: 76 on 2011-10-27
