Hello, I'm trying to build a map on a PR2, and am not able to move the robot via the rviz "2D Nav Goal". Here are the steps I've taken:
-on the PR2: $roslaunch pr2_2dnav_slam pr2_2dnav.launch
-on another computer: $roslaunch pr2_navigation_slam rviz_move_base_slam.launch
-try to set nav goal: This does not move the robot. Setting "rostopic echo move_base_simple/goal" on both the PR2 and rviz computers shows that the "move_base_simple/goal" message is being sent (ie, message shows up on both machines), but for some reason does not result in any actual movement. It almost seems like the move_base node isn't subscribed to the "move_base_simple/goal" topic.
Any help is greatly appreciated. Evan
EDIT: This turned out to be a hostname issue, where the machine sending the message wasn't being properly resolved.
Originally posted by evan on ROS Answers with karma: 41 on 2011-10-25
Originally posted by evan with karma: 41 on 2012-01-09
Comment by NikolasEngelhard on 2012-03-15:
Could you say a bit more about your problem and how you solved it? I currently have the same problem on our PR2.
