I get a compilation error when trying to subscribe to a ROS topic using an overloaded callback function. Look like the compiler doesn't know what function to pick.
Is there any way to solve it?
At compiling time I don't know which of several topics will my node subscribe to. The types of the possible topics are different, so I need different functions to receive the data. Is there any way of knowing the data type of a topic other than calling 'rostopic type [topic]' inside the node?
In the following snippet I want to subscribe to the "inputs" topic, but I don't know which topic will be mapped to it from the command line. I want to consider two possible topics with different data type "sr_robot_msgs::JointControllerState" and "pr2_controllers_msgs::JointControllerState", so how can I retrieve this data type information from the topic in runtime?
    MovementPublisher::MovementPublisher(double min_value, double max_value,
                                   double rate, unsigned int repetition, unsigned int nb_mvt_step, std::string controller_type)
sub_ = nh_tilde.subscribe("inputs", nb_mvt_step, &MovementPublisher::calculateErrorCallback, this);
void MovementPublisher::calculateErrorCallback(const sr_robot_msgs::JointControllerState::ConstPtr& msg)
double error = msg->set_point - msg->process_value;
ROS_DEBUG_STREAM("Error: " << error);
void MovementPublisher::pr2_calculateErrorCallback(const pr2_controllers_msgs::JointControllerState::ConstPtr& msg)
Originally posted by toniOliver on ROS Answers with karma: 159 on 2011-10-18
Comment by Lorenzo Riano on 2011-10-18:
Can you edit your answer to add a code snippet as an example? They problem with strongly typed languages is that you can't play with the types at run time. You could play with an if-then-else, but I need a sample code to work with.
Unfortunately you can't do this in C++.
First of all, if you subscribe to a topic with message type A and receive message type B, ROS will complain about the MD5 sum.
Even if it was possible, your approach can't do any real-time checking, as the C++ templates (implemented in the subscriber) create functions/classes at compile time.
So the main problem is that C++ requires the declaration of the callback function signature at compile time. AFAIK there is no general "Message" class from which all the messages inherit, so polymorphism is not an option.
This example seems to arise from the fact that "sr_robot_msgs::JointControllerState" and "pr2_controllers_msgs::JointControllerState" are basically the same message, so why two different types?
Originally posted by Lorenzo Riano with karma: 1342 on 2011-10-18
Comment by Lorenzo Riano on 2011-10-20:
Good, that's a sound solution. You might want to post the solution and mark this question as "solved", so future users will know the answer.
Comment by toniOliver on 2011-10-20:
Thank you. Finally I added a parameter in the node invocation that tells which format will the topic have. In this case I find it preferable to asking ROS about the data type of the topic.
Comment by Lorenzo Riano on 2011-10-19:
Right, so Python obviously can! I have edited my answer to reflect this.
Comment by Yianni on 2011-10-19:
Can the following thread be of any help regarding runtime checking? http://answers.ros.org/question/804/how-to-obtain-the-msg-format-of-a-topic-on-runtime
